查看: 33540|回复: 21
[求助] ic610安装 之后 输入 lmli 出现 1:14:57 (lmgrd) Unknown host: linyu 怎么解决
发表于 2012-9-25 01:32:25 | 显示全部楼层 |阅读模式
[lynn@linyu 桌面]$ lmli
[lynn@linyu 桌面]$  1:14:57 (lmgrd) -----------------------------------------------
1:14:57 (lmgrd)   Please Note:
1:14:57 (lmgrd)
1:14:57 (lmgrd)   This log is intended for debug purposes only.
1:14:57 (lmgrd)   In order to capture accurate license
1:14:57 (lmgrd)   usage data into an organized repository,
1:14:57 (lmgrd)   please enable report logging. Use Macrovision's
1:14:57 (lmgrd)   software license administration  solution,
1:14:57 (lmgrd)   FLEXnet Manager, to  readily gain visibility
1:14:57 (lmgrd)   into license usage data and to create
1:14:57 (lmgrd)   insightful reports on critical information like
1:14:57 (lmgrd)   license availability and usage. FLEXnet Manager
1:14:57 (lmgrd)   can be fully automated to run these reports on
1:14:57 (lmgrd)   schedule and can be used to track license
1:14:57 (lmgrd)   servers and usage across a heterogeneous
1:14:57 (lmgrd)   network of servers including Windows NT, Linux
1:14:57 (lmgrd)   and UNIX. Contact Macrovision at
1:14:57 (lmgrd)   www.macrovision.com for more details on how to
1:14:57 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
1:14:57 (lmgrd)   for your enterprise.
1:14:57 (lmgrd)
1:14:57 (lmgrd)
1:14:57 (lmgrd)
1:14:57 (lmgrd) EXITING DUE TO SIGNAL 33
我的系统是redhat 6.2的,
还有当我忽略这个问题后 直接输入 icfb& 会出现如下状况
[lynn@linyu 桌面]$ icfb &
[1] 5934
[lynn@linyu 桌面]$ *WARNING* Unable to find font name: "-*-courier-medium-r-*-*-12-*".
*WARNING* Cannot find textFont.  Trying font "fixed".
*WARNING* Unable to find font name: "-*-helvetica-medium-r-*-*-12-*".
*WARNING* Using the text font to present labels.
请给位大侠帮忙解决
发表于 2012-9-25 10:00:08 | 显示全部楼层
1) 把你的版权文件的头两行贴出来看一下
2) 查一下你的环境变量 $CDS_LIC_FILE和$LM_LICENSE_FILE
 楼主| 发表于 2012-9-25 23:50:31 | 显示全部楼层
回复 2# amodaman
这是  license 的 前两行
SERVER linyu ANY 5280
DAEMON cdslmd /home/lynn/eda/ic610/tools/bin/cdslmd
这是我往 .bashrc 中添加的内容。
alias lmli='/home/lynn/eda/ic610/tools/bin/lmgrd -c /home/lynn/eda/ic610/share/license/license.dat'
export OA_HOME=/home/lynn/eda/ic610/OA
export CDS_ROOT=/home/lynn/eda/ic610
export MMSIM_ROOT=/home/lynn/eda/mmsim61
export CDS_LIC_FILE=5280@linyu
export LM_LICENSE_FILE=$CDS_ROOT/share/license/license.dat
export CDS_Netlisting_Mode=Analog
export PATH=$MMSIM_ROOT/tools/bin:$MMSIM_ROOT/tools/spectre/bin:$CDS_ROOT/tools/bin:$CDS_ROOT/tools/dfII/bin:$PATH
export MOZILLA_HOME=/usr/bin/netscape
 楼主| 发表于 2012-9-25 23:51:34 | 显示全部楼层
回复 3# lynn13579
不好意思啊,那个笑脸时系统自动加的
发表于 2012-9-26 08:46:24 | 显示全部楼层
1)  不要把lmgrd命令放在.bashrc中, 这个脚本是每次打开窗口都会执行的脚本。lmgrd除了在第一次执行会成功之外,后面的所有执行都会因为端口占用而失败。你最好把这个命令放在.bash_profile中,只有机器启动并登录的时候才执行一次。当然,如果有管理员权限,放在/etc/rc.local文件中可以保证每次启动机器的时候执行也可以- 不管你用不用Cadence!
2)你试一下命令echo $HOSTNAME看看你的主机名称叫什么。
发表于 2012-9-26 09:02:54 | 显示全部楼层
学习中
 楼主| 发表于 2012-9-27 00:03:38 | 显示全部楼层
回复 5# amodaman
1)按您说的 我把lmgrd命令放在.bash_profile中 还是不好用,开始输入lmli时显示没有这个命令
于是我source了这个文件 还是和上边出现了同样的问题 Unknown host: linyu
2)我按您给提供的命令查了一下主机名,确实是叫linyu。
发表于 2012-9-27 10:55:44 | 显示全部楼层
回复 7# lynn13579
1) lmgrd命令本身在机器启动后运行一次就可以了,作为版权服务进程一直在那里。不用每次开窗口都运行的。当然你原来的脚本也不是每次都运行,而是每次都定义lmgrd的别名。这没什么问题,但是也没有必要。自己知道这个命令只需运行一次就好了。
2)你的操作系统设置有问题,看一下你的主机定义的文件:/etc/hosts 里面有没有对你的主机名有定义。比如缺省的主机名定义应该是这样:
127.0.0.1 localhost.localdomain localhost <my_host>.<my_domain> <myhost>
是否你的应该写成
127.0.0.1 linyu
自己试一下吧。
 楼主| 发表于 2012-9-28 01:19:23 | 显示全部楼层
回复 8# amodaman
太厉害了,经您指导上述问题得以解决,但现在又出现了新问题:
1)出现了类似3D 没禁止的语句,下面的代码是我从中截取的带有 “==>FEATURE” 的部分 。
0:48:43 (lmgrd) US Patents 5,390,297 and 5,671,412. 0:48:43 (lmgrd) World Wide Web:  http://www.macrovision.com
0:48:43 (lmgrd) License file(s): /home/lynn/eda/ic610/share/license/license.dat
0:48:43 (lmgrd) lmgrd tcp-port 5280
0:48:43 (lmgrd) Starting vendor daemons ...
0:48:43 (lmgrd) Started cdslmd (internet tcp_port 49080 pid 3660)
0:48:43 (cdslmd) FLEXnet Licensing version v10.8.0.7 build 26147
0:48:44 (cdslmd) Invalid license key (inconsistent authentication code)
0:48:44 (cdslmd)
==>FEATURE Cadence_3D_Design_Viewer cdslmd 16.0 31-dec-2025 uncounted \
01357D06E4AD VENDOR_STRING=Team_EFA_2006 HOSTID=ANY ck=78 \
SIGN2="0D0D EA79 E0C1 4F48 4DCF 770A E1AE F9EF 70FB FF11 B46D \
CB35 F1D2 9A45 F4A3 05E1 EB0A CEF4 8396 87BA 7B4A BA27 CED9 \
F214 BED4 2DC6 BF6A F385 8BDA C611"
0:48:44 (cdslmd)
==>FEATURE Capture cdslmd 16.0 31-dec-2025 uncounted FC5BE9761A8C \
VENDOR_STRING=Team_EFA_2006 HOSTID=ANY ck=115 SIGN2="172D DEBE \
A0EB 398F CC4A 6F83 94C4 9562 ED81 D592 F833 18A4 F5A7 009E \
EBE4 0F57 1D31 3017 21F4 CE68 9C92 4062 39AF 69FA 9B04 DEA3 \
我 按网上的教程 使用geidt /etc/X11/xorg.conf
写入
Section "Extensions"
Option "Composite" "Disable"
EndSection
但没有奏效。
2) 我忽略上述问题 ,在终端输入 icfb& 时, 终端出现如下代码:
[lynn@linyu ~]$ *WARNING* Unable to find font name: "-*-courier-medium-r-*-*-12-*".
此时已经可以进入cadence中了,然后再cadence中的CIW窗口出现了:
*WARNING* Using text font to present error messages.
Warning: Cannot convert string "-adobe-helvetica-bold-r-*-*-12-*-*-*-*-*-*-*" to type FontStruct
Warning: Cannot convert string "-adobe-courier-medium-r-*-*-12-*-*-*-*-*-*-*" to type FontStruct
Warning: Cannot convert string "-adobe-helvetica-bold-r-*-*-12-120-*-*-*-*-iso8859-1" to type FontStruct
Warning: Cannot convert string "-adobe-courier-medium-r-*-*-12-120-*-*-*-*-iso8859-1" to type FontStruct
Warning: Cannot convert string "-adobe-courier-bold-r-*-*-12-120-*-*-*-*-iso8859-1" to type FontStruct
Loading schematic.cxt
Loading lo.cxt
*WARNING* The display packet information '90' for 'display' was not found.
不知道是因为第一个问题,而导致第二个问题的出现,还是本身字体的问题,或是其他原因呢?
发表于 2012-9-28 10:40:53 | 显示全部楼层
1) 去掉一个feature的正确方法是在那一行添加 #, 对于用 \ 字符作结尾的连续行,需要每一行都添加 #, 这样才能干净完整的剔除掉你不需要的feature
2) 需要检查一下系统检索的字体文件是否存在。最简单的就是把Cadence 装载目录下的.Xdefaults文件拷贝到自己的$HOME目录下。$CDS_ROOT/tools/dfII/local/.Xdefaults. 另外需要了解系统启动的时候是否需要执行xrdb .Xdfaults 命令。当然如果字体文件不存在的话,需要检查一下你的操作系统的X11是否安装完整了。
GMT+8, 2025-9-14 13:25 , Processed in 0.016825 second(s), 3 queries , Gzip On, Redis On.
