查看: 10001|回复: 16
[求助] 做过sigma delta ADC进来下!!!!!!
发表于 2012-9-5 11:53:45 | 显示全部楼层 |阅读模式
自己做实验发现,电路模拟出来的噪底不够低为什么??? 从形状来开也达到了5阶整形的效果,但是电路级仿真出来做的图还是不令人满意!!
做为模型,右为电路
做为模型,右为电路
发表于 2012-9-6 04:45:49 | 显示全部楼层
Opamp gain  gbw
发表于 2012-9-6 11:04:33 | 显示全部楼层
Check your simulation accuracy, not sure what sort tool u were using.
发表于 2012-9-7 13:46:53 | 显示全部楼层
CT or DT?
check the poles and zeros
 楼主| 发表于 2012-9-7 14:50:24 | 显示全部楼层
回复 3# steve_guo_1997
   SPECTRE
发表于 2012-9-7 18:47:18 | 显示全部楼层
回复 5# askermm
if u were using tran simulation to verify its SNR, this means no actual device noise source was introduced in the final results.
so, there was only several factors that may have influence on your simulation aside from device noise, like
quantization noise (leakage in your loop filter, intermodulation due to  non-linearity , due to modulation if any chopper exists ...)
another possible source is tran algorithm noise introduced by simulator.
I am not sure about your simulation setup or your modulator structure.
if my remember is right, i changed the tolerance setup a lit bit higher than just set the tran simulation accuracy into "conservative " and i should say this was the setup i used in a 16bit SNR SD modulator. Nevertheless, this setup is something relevant to the ckt and may not be suitable for your ckt.
my suggestion is to set the accuracy one step higher than before until the SNR reach stable. Finally, u would get the optimized simulator setup.
发表于 2012-9-7 19:40:21 | 显示全部楼层
回复 6# steve_guo_1997
    这仿真速度实在是要命啊
发表于 2012-9-7 19:43:40 | 显示全部楼层
回复 7# hsh22
You almost have no choice. you may choose a  spectre version with multi processor support and hspice may be a better alternative.
 楼主| 发表于 2012-9-7 23:37:42 | 显示全部楼层
回复 4# gliang1986
   DT.  it is not easy to check in circuit!!!
 楼主| 发表于 2012-9-7 23:44:25 | 显示全部楼层
   have you looked my picture carefully? you can see only three points in my first fig, but more than points in my second fig. why? BTW, i also use "conservative" in my simulator.
GMT+8, 2025-12-19 17:47 , Processed in 0.018882 second(s), 4 queries , Gzip On, Redis On.
