smic13mmrf spectre仿真时出现错误,整体显示如下,红色部分是其错误显示,希望各位大侠帮忙看看是什么原因造成的。
Cadence (R) Virtuoso (R) Spectre (R) Circuit Simulator
Version 7.1.0.031 -- 15 Dec 2008
Copyright (C) 1989-2007 Cadence Design Systems, Inc. All rights reserved worldwide. Cadence, Virtuoso and Spectre are registered trademarks of Cadence Design Systems, Inc. All others are the property of their respective holders.
Protected by U.S. Patents:
5,610,847; 5,790,436; 5,812,431; 5,859,785; 5,949,992; 5,987,238;
6,088,523; 6,101,323; 6,151,698; 6,181,754; 6,260,176; 6,278,964;
6,349,272; 6,374,390; 6,493,849; 6,504,885; 6,618,837; 6,636,839;
6,778,025; 6,832,358; 6,851,097; 6,928,626; 7,024,652; 7,035,782;
7,085,700; 7,143,021.
Includes RSA BSAFE(R) Cryptographic or Security Protocol Software from RSA Security, Inc.
User: zhw Host: icfb HostID: 7F0100 PID: 13502
Memory available: 811.3029 MB physical: 1.6086 GB
CPU(1 of 2): CPU 0 Pentium(R) Dual-Core CPU T4200 @ 2.00GHz 2000.789MHz
Simulating `input.scs' on icfb at 7:21:22 PM, Thur May 31, 2012 (process id: 13502).
Command line:
/eda/cadence/mmsim710/tools.lnx86/spectre/bin/32bit/spectre -env \
artist5.1.0 +escchars +log ../psf/spectre.out +inter=mpsc \
+mpssession=spectre4_11318_10 -format sst2 -raw ../psf \
+lqtimeout 900 -maxw 5 -maxn 5 input.scs
spectre pid = 13502
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libinfineon_sh.so ...
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libphilips_sh.so ...
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libsparam_sh.so ...
Loading /eda/cadence/mmsim710/tools.lnx86/cmi/lib/5.0/libstmodels_sh.so ...
Auto-loading AHDL component.
Finished loading AHDL component in 0 s (elapsed).
Installed AHDL simulation interface.
Fatal error found by spectre during AHDL read-in.
FATAL (VACOMP-2096): File '/export/home/zhw/smic13mmrf_1225_1P2M_200712311746/smic13mmrf_1225_1P2M_200712311746/smic13mmrf_1225/../models/spectre/res.def' does not appear to be a valid Verilog-A file. In previous releases, '.def' was a file extension typically used for SpectreHDL files but SpectreHDL is no longer supported. If this file is a SpectreHDL file, you need to replace it with an equivalent Verilog-A file.
Aggregate audit (7:21:23 PM, Thur May 31, 2012):
Time used: CPU = 922 ms, elapsed = 1 s, util. = 92.2%.
Time spent in licensing: elapsed = 701 ms, percentage of total = 70.1%.
Virtual memory used = 9 Mbytes.
spectre completes with 1 error, 0 warnings, and 0 notices.
spectre terminated prematurely due to fatal error. |
