查看: 12624|回复: 22
SCL11.2的license文件如何生成?
发表于 2012-5-13 09:19:25 | 显示全部楼层 |阅读模式
用EDA0.4b生成后,出现如下错误,换成SCL10.9.3就OK:
0:54:32 (snpslmd) EXTERNAL FILTERS are OFF
0:54:32 (lmgrd) snpslmd using TCP-port 53236
0:54:32 (snpslmd) Serving features for the following vendor names:
snpslmd  CADABRA  EPIC  ISE-TCADd  TE_CATS  adalmd  anagram  archprod  avantd  chrysalisd  cowared  everest  hscd  innologd  la_dmon  leda  metasoftd  nassd  numeritchd  pdld  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synforad  synopsysd  synplctyd  tmald  vastlmd  vcsd
00:54:32 (snpslmd) ------------------------------------------------------------------
00:54:32 (snpslmd) ERROR: Synopsys License Server does not support FEATURE lines (400,501).
00:54:32 (snpslmd) Contact Synopsys Support Center to resolve this issue.
00:54:32 (snpslmd) Please send this error code to support_center@synopsys.com.
 楼主| 发表于 2012-5-13 21:53:06 | 显示全部楼层
貌似EFA0.4b生成的已经不能用了!!!
发表于 2012-5-16 23:10:22 | 显示全部楼层
EFA0.4b生成的license不能用在scl11.0以上
发表于 2012-5-30 18:01:10 | 显示全部楼层
Thank you!!!!
发表于 2012-9-18 15:44:55 | 显示全部楼层
求解啊
发表于 2012-10-17 23:29:12 | 显示全部楼层
Is there a EFA version which works with SCL 11.x?
发表于 2012-10-26 17:29:01 | 显示全部楼层
回复 3# sawan
    那要用什么产生license呢?
发表于 2012-10-28 04:11:07 | 显示全部楼层
is there any EFA licgen that works with scl 11.x?
Pls, reply
发表于 2012-10-28 06:20:55 | 显示全部楼层
No answer?
发表于 2012-11-21 06:56:45 | 显示全部楼层
No answer?
GMT+8, 2025-6-26 15:38 , Processed in 0.026968 second(s), 8 queries , Gzip On, MemCached On.
