为什么要同步wptr、rptr? 就是20-27行的程序则怎么解释?
- module fifo1(rdata, wfull, rempty, wdata, winc, wclk, wrst_n,rinc, rclk, rrst_n);
- parameter DSIZE = 8; parameter ASIZE = 4;
- output [DSIZE-1:0] rdata;
- output wfull;
- output rempty;
- input [DSIZE-1:0] wdata;
- input winc, wclk, wrst_n;
- input rinc, rclk, rrst_n;
- reg wfull,rempty;
- reg [ASIZE:0] wptr, rptr, wq2_rptr, rq2_wptr, wq1_rptr,rq1_wptr;
- reg [ASIZE:0] rbin, wbin;
- reg [DSIZE-1:0] mem[0:(1<<ASIZE)-1]; //定义存储器宽度为8,深度为16
- wire [ASIZE-1:0] waddr, raddr; //读写地址
- wire [ASIZE:0] rgraynext, rbinnext,wgraynext,wbinnext; //读写的格雷码与二进制码
- wire rempty_val,wfull_val;
- //-----------------双口RAM存储器--------------------
- assign rdata=mem[raddr];
- always@(posedge wclk)
- if (winc && !wfull) mem[waddr] <= wdata;
- //-------------同步rptr 指针-------------------------
- always @(posedge wclk or negedge wrst_n)
- if (!wrst_n) {wq2_rptr,wq1_rptr} <= 0;
- else {wq2_rptr,wq1_rptr} <= {wq1_rptr,rptr}; //这里采用了位拼接操作符
- //-------------同步wptr指针---------------------------
- always @(posedge rclk or negedge rrst_n)
- if (!rrst_n) {rq2_wptr,rq1_wptr} <= 0;
- else {rq2_wptr,rq1_wptr} <= {rq1_wptr,wptr}; //
- //-------------rempty产生与raddr产生-------------------
- always @(posedge rclk or negedge rrst_n) // GRAYSTYLE2 pointer
- begin
- if (!rrst_n) {rbin, rptr} <= 0;
- else {rbin, rptr} <= {rbinnext, rgraynext};
- end
- // Memory read-address pointer (okay to use binary to address memory)
- assign raddr = rbin[ASIZE-1:0];
- assign rbinnext = rbin + (rinc & ~rempty);
- assign rgraynext = (rbinnext>>1) ^ rbinnext; //产生读格雷码
- // FIFO empty when the next rptr == synchronized wptr or on reset
- assign rempty_val = (rgraynext == rq2_wptr);
- begin
- if (!rrst_n) rempty <= 1'b1;
- else rempty <= rempty_val;
- end
- //---------------wfull产生与waddr产生------------------------------
- always @(posedge wclk or negedge wrst_n) // GRAYSTYLE2 pointer
- if (!wrst_n) {wbin, wptr} <= 0;
- else {wbin, wptr} <= {wbinnext, wgraynext};
- // Memory write-address pointer (okay to use binary to address memory)
- assign waddr = wbin[ASIZE-1:0];
- assign wbinnext = wbin + (winc & ~wfull);
- assign wgraynext = (wbinnext>>1) ^ wbinnext; //产生写格雷码
- assign wfull_val = (wgraynext=={~wq2_rptr[ASIZE:ASIZE-1], wq2_rptr[ASIZE-2:0]}); //:ASIZE-1]
- if (!wrst_n) wfull <= 1'b0;
- else wfull <= wfull_val;
- endmodule
复制代码 |
