查看: 9273|回复: 6
[招聘] 经典IC设计面试问题9
发表于 2010-11-28 04:26:06 | 显示全部楼层 |阅读模式
Casex,z difference,which is preferable,why?
CASEZ :
Special version of the case statement which uses a Z logic value to represent don't-care bits. CASEX :
Special version of the case statement which uses Z or X logic values to represent don't-care bits.
CASEZ should be used for case statements with wildcard don抰 cares, otherwise use of CASE is required; CASEX should never be used.
This is because:
Don抰 cares are not allowed in the "case" statement. Therefore casex or casez are required. Casex will automatically match any x or z with anything in the case statement. Casez will only match z抯 -- x抯 require an absolute match.
发表于 2010-11-28 17:45:49 | 显示全部楼层
good information !!!
发表于 2011-1-20 20:36:41 | 显示全部楼层
恩,实际有点用
发表于 2011-6-13 19:52:45 | 显示全部楼层
youxie yong ,neng geng xiang xi hui geng hao ,xiexie sir
发表于 2011-6-14 22:02:11 | 显示全部楼层
嗯,谢谢分享
发表于 2011-6-16 09:59:01 | 显示全部楼层
谢谢分享
发表于 2011-6-18 18:40:40 | 显示全部楼层
GMT+8, 2025-8-20 00:30 , Processed in 0.017327 second(s), 5 queries , Gzip On, Redis On.
