查看: 86791|回复: 377
[资料] ISSCC 2011 文章目录 & 分论文下载【适合只需下部分文章的朋友】
发表于 2011-3-5 15:50:38 | 显示全部楼层 |阅读模式
ISSCC 2011 Sessions and Articles List [目录下方即下载地址]
Session 1 - Plenary
   1.0 - Session 1 Overview: Plenary
   1.1 - New Interfaces to the Body Through Implantable System Integration
   1.2 - Game-Changing Opportunities for Wireless Personal Healthcare and Lifestyle
   1.3 - Eco-Friendly Semiconductor Technologies for Healthy Living
   1.4 - Beyond the Horizon: The Next 10x Reduction in Power - Challenges and Solutions
D01_01.pdf (1.43 MB , 下载次数: 95 )
D01_02.pdf (485.29 KB , 下载次数: 56 )
D01_03.pdf (603.68 KB , 下载次数: 52 )
D01_04.pdf (2.39 MB , 下载次数: 99 )
Session 2 - Technologies For Health
   2.0 - Session 2 Overview: Technologies For Health
   2.1 - A 0.24nJ/b Wireless Body-Area-Network Transceiver with Scalable Double-FSK Modulation
   2.2 - A 75μW Real-Time Scalable Network Controller and a 25μW ExG Sensor IC for Compact Sleep-Monitoring Applications
   2.3 - A 3µW Wirelessly Powered CMOS Glucose Sensor for an Active Contact Lens
   2.4 - A 90nm CMOS SoC UWB Pulse Radar for Respiratory Rate Monitoring
   2.5 - A Broadband THz Imager in a Low-Cost CMOS Technology
   2.6 - A Programmable Implantable Micro-Stimulator SoC with Wireless Telemetry: Application in Closed-Loop Endocardial Stimulation for Cardiac Pacemaker
   2.7 - A 660pW Multi-Stage Temperature-Compensated Timer for Ultra-Low-Power Wireless Sensor Node Synchronization
   2.8 - A Low-Power Fully Integrated RF Locked Loop for Miniature Atomic Clock
D02_01.pdf (2.03 MB , 下载次数: 70 )
D02_02.pdf (681.72 KB , 下载次数: 51 )
D02_03.pdf (1.16 MB , 下载次数: 37 )
D02_04.pdf (2.38 MB , 下载次数: 58 )
D02_05.pdf (938.19 KB , 下载次数: 39 )
D02_06.pdf (1.81 MB , 下载次数: 47 )
D02_07.pdf (2.27 MB , 下载次数: 109 )
D02_08.pdf (1.31 MB , 下载次数: 59 )
Session 3 - RF Techniques
   3.0 - Session 3 Overview: RF Techniques
   3.1 - Spur-Free All-Digital PLL in 65nm for Mobile Phones
   3.2 - A 5.3GHz Digital-to-Time-Converter-Based Fractional-N All-Digital PLL
   3.3 - A 2.5GHz 32nm 0.35mm2 3.5dB NF -5dBm P1dB Fully Differential CMOS Push-Pull LNA with Integrated 34dBm T/R Switch and ESD Protection
   3.4 - A 65nm CMOS Pulse-Width-Controlled Driver with 8Vpp Output Voltage for Switch-Mode RF PAs up to 3.6GHz
   3.5 - A Low-Power Process-Scalable Superheterodyne Receiver with Integrated High-Q Filters
   3.6 - A 40nm CMOS Highly Linear 0.4-to-6GHz Receiver Resilient to 0dBm Out-of-Band Blockers
   3.7 - A 1.0-to-4.0GHz 65nm CMOS Four-Element Beamforming Receiver Using a Switched-Capacitor Vector Modulator with Approximate Sine Weighting via Charge Redistribution
   3.8 - A Harmonic Rejection Mixer Robust to RF Device Mismatches
D03_01.pdf (11.24 MB , 下载次数: 219 )
D03_02.pdf (3.92 MB , 下载次数: 160 )
D03_03.pdf (432.42 KB , 下载次数: 126 )
D03_04.pdf (829.81 KB , 下载次数: 94 )
D03_05.pdf (1.65 MB , 下载次数: 110 )
D03_06.pdf (2.39 MB , 下载次数: 137 )
D03_07.pdf (4.1 MB , 下载次数: 120 )
D03_08.pdf (12.49 MB , 下载次数: 206 )
Session 4 - Enterprise Processors & Components
   4.0 - Session 4 Overview: Enterprise Processors & Components
   4.1 - A 5.2GHz Microprocessor Chip for the IBM zEnterpriseTM System
   4.2 - Dynamic Hit Logic with Embedded 8Kb SRAM in 45nm SOI for the zEnterpriseTM Processor
   4.3 - A 32nm Westmere-EX Xeon® Enterprise Processor
   4.4 - Godson-3B: A 1GHz 40W 8-Core 128GFLOPS Processor in 65nm CMOS
   4.5 - Design Solutions for the Bulldozer 32nm SOI 2-Core Processor Module in an 8-Core CPU
   4.6 - 40-Entry Unified Out-of-Order Scheduler and Integer Execution Unit for the AMD Bulldozer x86-64 Core
   4.7 - Clock Generation for a 32nm Server Processor with Scalable Cores
   4.8 - A 32nm 3.1 Billion Transistor 12-Wide-Issue Itanium® Processor for Mission-Critical Servers
D04_01.pdf (1.04 MB , 下载次数: 100 )
D04_02.pdf (351.34 KB , 下载次数: 46 )
D04_03.pdf (1.84 MB , 下载次数: 43 )
D04_04.pdf (1.37 MB , 下载次数: 75 )
D04_05.pdf (1.15 MB , 下载次数: 39 )
D04_06.pdf (561.54 KB , 下载次数: 54 )
D04_07.pdf (1.9 MB , 下载次数: 59 )
D04_08.pdf (3 MB , 下载次数: 49 )
Session 5 - PLLs
   5.0 - Session 5 Overview: PLLs
   5.1 - A 2.9-to-4.0GHz Fractional-N Digital PLL with Bang-Bang Phase Detector and 560fsrms Integrated Jitter at 4.5mW Power
   5.2 - An Injection-Locked Ring PLL with Self-Aligned Injection Window
   5.3 - A 0.4-to-3GHz Digital PLL with Supply-Noise Cancellation Using Deterministic Background Calibration
   5.4 - A 0.1-fref BW 1GHz Fractional-N PLL with FIR-Embedded Phase-Interpolator-Based Noise Filtering
   5.5 - A Scalable sub-1.2mW 300MHz-to-1.5GHz Host-Clock PLL for System-on-Chip in 32nm CMOS
   5.6 - A 570fsrms Integrated-Jitter Ring-VCO-Based 1.21GHz PLL with Hybrid Loop
   5.7 - A Rotary-Traveling-Wave-Oscillator-Based All-Digital PLL with a 32-Phase Embedded Phase-to-Digital Converter in 65nm CMOS
D05_01.pdf (1.7 MB , 下载次数: 255 )
D05_02.pdf (439.96 KB , 下载次数: 184 )
D05_03.pdf (642.4 KB , 下载次数: 177 )
D05_04.pdf (1.71 MB , 下载次数: 205 )
D05_05.pdf (720.81 KB , 下载次数: 139 )
D05_06.pdf (655.38 KB , 下载次数: 204 )
D05_07.pdf (351.25 KB , 下载次数: 149 )
Session 6 - Sensors & Energy Harvesting
   6.0 - Session 6 Overview: Sensors & Energy Harvesting
   6.1 - A Low-Power 3-Axis Digital-Output MEMS Gyroscope with Single Drive and Multiplexed Angular Rate Readout
   6.2 - A 50mW CMOS Wind Sensor with ±4% Speed and ±2° Direction Error
   6.3 - A Telemetric Stress-Mapping CMOS Chip with 24 FET-Based Stress Sensors for Smart Orthodontic Brackets
   6.4 - A 21b ±40mV Range Read-Out IC for Bridge Transducers
   6.5 - A ±1.5% Nonlinearity 0.1-to-100A Shunt Current Sensor Based on a 6kV Isolated Micro-Transformer for Electrical Vehicles and Home Automation
   6.6 - Indirect X-ray Photon-Counting Image Sensor with 27T Pixel and 15e-rms Accurate Threshold
   6.7 - A 1.32pW/frame•pixel 1.2V CMOS Energy-Harvesting and Imaging (EHI) APS Imager
   6.8 - 5µW-to-10mW Input Power Range Inductive Boost Converter for Indoor Photovoltaic Energy Harvesting with Integrated Maximum Power Point Tracking Algorithm
    6.9 - A Self-Supplied Inertial Piezoelectric Energy Harvester with Power-Management IC
D06_01.pdf (3.37 MB , 下载次数: 145 )
D06_02.pdf (890 KB , 下载次数: 46 )
D06_03.pdf (2.29 MB , 下载次数: 34 )
D06_04.pdf (1.04 MB , 下载次数: 44 )
D06_05.pdf (988.49 KB , 下载次数: 36 )
D06_06.pdf (798.95 KB , 下载次数: 35 )
D06_07.pdf (1.51 MB , 下载次数: 42 )
D06_08.pdf (3.02 MB , 下载次数: 51 )
D06_09.pdf (3.37 MB , 下载次数: 49 )
Session 7 - Multimedia & Mobile
   7.0 - Session 7 Overview: Multimedia & Mobile
   7.1 - A 216fps 4096 2160p 3DTV Set-Top Box SoC for Free-Viewpoint 3DTV Applications
   7.2 - A Highly Parallel and Scalable CABAC Decoder for Next-Generation Video Coding
   7.3 - A 275mW Heterogeneous Multimedia Processor for IC-Stacking on Si-Interposer
   7.4 - A 57mW Embedded Mixed-Mode Neuro-Fuzzy Accelerator for Intelligent Multi-core Processor
   7.5 - A 28nm 0.6V Low-Power DSP for Mobile Applications
   7.6 - A MIMO WiMAX SoC in 90nm CMOS for 300km/h Mobility
   7.7 - A 70Mb/s -100.5dBm Sensitivity 65nm LP MIMO Chipset for WiMAX Portable Router
   7.8 - A Direct Digital Frequency Synthesizer with Minimized Tuning Latency of  12ns
D07_02.pdf (902.6 KB , 下载次数: 37 )
D07_03.pdf (1.16 MB , 下载次数: 28 )
D07_05.pdf (843.28 KB , 下载次数: 40 )
D07_06.pdf (1.44 MB , 下载次数: 43 )
D07_07.pdf (448.45 KB , 下载次数: 30 )
D07_08.pdf (1.17 MB , 下载次数: 72 )
Session 8 - Architectures & Circuits for Next-Generation Wireline Transceivers
   8.0 - Session 8 Overview: Architectures & Circuits for Next-Generation Wireline Transceivers
   8.1 - 11.3Gb/s CMOS SONET-Compliant Transceiver for Both RZ and NRZ Applications
   8.2 - A Full-Duplex 10GBase-T Transmitter Hybrid with SFDR >65dBc Over 1 to 400MHz in 40nm CMOS
   8.3 - A 40Gb/s TX and RX Chip Set in 65nm CMOS
   8.4 - 10:4 MUX and 4:10 DEMUX Gearbox LSI for 100-Gigabit Ethernet Link
   8.5 - A 12.5+12.5Gb/s Full-Duplex Plastic Waveguide Interconnect
   8.6 - A Highly Digital 0.5-to-4Gb/s 1.9mW/Gb/s Serial-Link Transceiver Using Current-Recycling in 90nm CMOS
   8.7 - A 1-to-6Gb/s Phase-Interpolator-Based Burst-Mode CDR in 65nm CMOS
   8.8 - A 14Gb/s High-Swing Thin-Oxide Device SST TX in 45nm CMOS SOI
D08_01.pdf (1.02 MB , 下载次数: 132 )
D08_02.pdf (525.54 KB , 下载次数: 106 )
D08_03.pdf (5.22 MB , 下载次数: 134 )
D08_04.pdf (605.06 KB , 下载次数: 104 )
D08_05.pdf (827.5 KB , 下载次数: 90 )
D08_06.pdf (573.31 KB , 下载次数: 126 )
D08_07.pdf (753.42 KB , 下载次数: 145 )
D08_08.pdf (1.5 MB , 下载次数: 127 )
Session 9 - Wireless & mm-Wave Connectivity
   9.0 - Session 9 Overview: Wireless & mm-Wave Connectivity
   9.1 - A 60GHz 16QAM/8PSK/QPSK/BPSK Direct-Conversion Transceiver for IEEE 802.15.3c
   9.2 - A 65nm CMOS Fully Integrated Transceiver Module for 60GHz Wireless HD Applications
   9.3 - A 60GHz CMOS Phased-Array Transceiver Pair for Multi-Gb/s Wireless Communications
   9.4 - A 65nm CMOS 4-Element Sub-34mW/Element 60GHz Phased-Array Transceiver
   9.5 - An 87GHz QPSK Transceiver with Costas-Loop Carrier Recovery in 65nm CMOS
   9.6 - A 65nm Dual-Band 3-Stream 802.11n MIMO WLAN SoC
   9.7 - A 0.46mm2 4dB-NF Unified Receiver Front-End for Full-Band Mobile TV in 65nm CMOS
   9.8 - An All-Digital 8-DPSK Polar Transmitter with Second-Order Approximation Scheme and Phase Rotation-Constant Digital PA for Bluetooth EDR in 65nm CMOS
    9.9 - A Digital-Intensive Receiver Front-End Using VCO-Based ADC with an Embedded 2nd-Order Anti-Aliasing Sinc Filter in 90nm CMOS
D09_01.pdf (7.38 MB , 下载次数: 93 )
D09_02.pdf (4.12 MB , 下载次数: 108 )
D09_03.pdf (2.01 MB , 下载次数: 104 )
D09_04.pdf (5.2 MB , 下载次数: 77 )
D09_05.pdf (1.94 MB , 下载次数: 152 )
D09_06.pdf (780.69 KB , 下载次数: 135 )
D09_07.pdf (9.05 MB , 下载次数: 105 )
D09_08.pdf (841.07 KB , 下载次数: 128 )
D09_09.pdf (439.74 KB , 下载次数: 71 )
Session 10 - Nyquist Rate Converters
   10.0 - Session 10 Overview: Nyquist Rate Converters
   10.1 - A 480mW 2.6GS/s 10b 65nm CMOS Time-Interleaved ADC with 48.5dB SNDR up to Nyquist
   10.2 - A 12b 1GS/s SiGe BiCMOS Two-Way Time-Interleaved Pipeline ADC
   10.3 - An 800MS/s Dual-Residue Pipeline ADC in 40nm CMOS
   10.4 - A 16b 80MS/s 100mW 77.6dB SNR CMOS Pipeline ADC
   10.5 - A 0.024mm2 8b 400MS/s SAR ADC with 2b/Cycle and Resistive DAC in 65nm CMOS
   10.6 - A Resolution-Reconfigurable 5-to-10b 0.4-to-1V Power Scalable SAR ADC
   10.7 - A 12b 1.25GS/s DAC in 90nm CMOS with >70dB SFDR up to 500MHz
   10.8 - A 56GS/s 6b DAC in 65nm CMOS with 256 6b memory
D10_01.pdf (726.94 KB , 下载次数: 133 )
D10_02.pdf (128.32 KB , 下载次数: 113 )
D10_03.pdf (405.84 KB , 下载次数: 104 )
D10_04.pdf (929.29 KB , 下载次数: 169 )
D10_05.pdf (1.73 MB , 下载次数: 146 )
D10_06.pdf (2.41 MB , 下载次数: 144 )
D10_07.pdf (370.15 KB , 下载次数: 118 )
D10_08.pdf (957.19 KB , 下载次数: 105 )
Session 11 - Non-Volatile Memory Solutions
   11.0 - Session 11 Overview: Non-Volatile Memory Solutions
   11.1 - A 151mm2 64Gb MLC NAND Flash Memory in 24nm CMOS Technology
   11.2 - A 4Mb Embedded SLC Resistive-RAM Macro with 7.2ns Read-Write Random-Access Time and 160ns MLC-Access Capability
   11.3 - A 32Gb MLC NAND Flash Memory with Vth Margin-Expanding Schemes in 26nm CMOS
   11.4 - 95%-Lower-BER 43%-Lower-Power Intelligent Solid-State Drive (SSD) with Asymmetric Coding and Stripe Pattern Elimination Algorithm
   11.5 - An Offset-Tolerant Current-Sampling-Based Sense Amplifier for Sub-100nA-Cell-Current Nonvolatile Memory
   11.6 - A Low-Voltage 1Mb FeRAM in 0.13µm CMOS Featuring Time-to-Digital Sensing for Expanded Operating Margin in Scaled CMOS
   11.7 - A 4Mb Conductive-Bridge Resistive Memory with 2.3GB/s Read-Throughput and 216MB/s Program-Throughput
   11.8 - A 7MB/s 64Gb 3-Bit/Cell DDR NAND Flash Memory in 20nm-Node Technology
D11_01.pdf (450.99 KB , 下载次数: 48 )
D11_02.pdf (1.58 MB , 下载次数: 33 )
D11_03.pdf (1.54 MB , 下载次数: 44 )
D11_04.pdf (414.51 KB , 下载次数: 55 )
D11_05.pdf (1.25 MB , 下载次数: 44 )
D11_06.pdf (2.6 MB , 下载次数: 39 )
D11_07.pdf (523.63 KB , 下载次数: 33 )
D11_08.pdf (800.51 KB , 下载次数: 45 )
Session 12 - Design in Emerging Technologies
   12.0 - Session 12 Overview: Design in Emerging Technologies
   12.1 - A 95mV-Startup Step-Up Converter with VTH-Tuned Oscillator by Fixed-Charge Programming and Capacitor Pass-On Scheme
   12.2 - 100V AC Power Meter System-on-a-Film (SoF) Integrating 20V Organic CMOS Digital and Analog Circuits with Floating Gate for Process-Variation Compensation and 100V Organic PMOS Rectifier
   12.3 - Real-Time Current-Waveform Sensor with Plugless Energy Harvesting from AC Power Lines for Home/Building Energy-Management Systems
   12.4 - A 3.9ns 8.9mW 4 4 Silicon Photonic Switch Hybrid Integrated with CMOS Driver
   12.5 - A 820GHz SiGe Chipset for Terahertz Active Imaging Applications
   12.6 - A 130μA Wake-Up Receiver SoC in 0.13μm CMOS for Reducing Standby Power of An Electric Appliance Controlled by An Infrared Remote Controller
   12.7 - Programmable Cell Array Using Rewritable Solid-Electrolyte Switch Integrated in 90nm CMOS
   12.8 - 6W/25mm2 Inductive Power Transfer for Non-Contact Wafer-Level Testing
    12.9 - GHz-Range Continuous-Time Programmable Digital FIR with Power Dissipation that Automatically Adapts to Signal Activity
D12_01.pdf (1.07 MB , 下载次数: 26 )
D12_02.pdf (4.43 MB , 下载次数: 17 )
D12_03.pdf (2.06 MB , 下载次数: 40 )
D12_04.pdf (1.11 MB , 下载次数: 21 )
D12_05.pdf (361.31 KB , 下载次数: 20 )
D12_06.pdf (1.57 MB , 下载次数: 36 )
D12_07.pdf (2.76 MB , 下载次数: 18 )
D12_08.pdf (2.29 MB , 下载次数: 24 )
D12_09.pdf (979.7 KB , 下载次数: 23 )
Session 13 - Analog Techniques
   13.0 - Session 13 Overview: Analog Technologies
   13.1 - A Simple LED Lamp Driver IC with Intelligent Power-Factor Correction
   13.2 - A 1.2A Buck-Boost LED Driver with 13% Efficiency Improvement Using Error-Averaged SenseFET-Based Current Sensing
   13.3 - Filterless Integrated Class-D Audio Amplifier Achieving 0.0012% THD+N and 96dB PSRR When Supplying 1.2W
   13.4 - A 5.9nV/ Hz Chopper Operational Amplifier with 0.78µV Maximum Offset and 28.3nV/°C Offset Drift
   13.5 - A Current-Feedback Instrumentation Amplifier with a Gain Error Reduction Loop and 0.06% Untrimmed Gain Error
   13.6 - A 6.7nV/ Hz Sub-mHz-1/f-Corner 14b Analog-to-Digital Interface for Rail-to-Rail Precision Voltage Sensing
   13.7 - A 36V JFET-Input Bipolar Operational Amplifier with 1µV/°C Maximum Offset Drift and -126dB Total Harmonic Distortion
   13.8 - A 3.3V-Supply 120mW Differential ADC Driver Amplifier in 0.18µm SiGe BiCMOS with 108dBc IM3 at 100MHz
D13_01.pdf (7.8 MB , 下载次数: 220 )
D13_02.pdf (655.22 KB , 下载次数: 128 )
D13_03.pdf (4.1 MB , 下载次数: 136 )
D13_04.pdf (1.34 MB , 下载次数: 188 )
D13_05.pdf (1.36 MB , 下载次数: 128 )
D13_06.pdf (503.56 KB , 下载次数: 96 )
D13_07.pdf (6.21 MB , 下载次数: 350 )
D13_08.pdf (477.19 KB , 下载次数: 95 )
Session 14 - High-Performance Embedded Memory
   14.0 - Session 14 Overview: High-Performance Embedded Technology
   14.1 - A 64Mb SRAM in 32nm High-k Metal-Gate SOI Technology with 0.7V Operation Enabled by Stability, Write-Ability and Read-Ability Enhancements
   14.2 - A 4R2W Register File for a 2.3GHz Wire-Speed POWERTM Processor with Double-Pumped Write Operation
   14.3 - An 8MB Level-3 Cache in 32nm SOI with Column-Select Aliasing
   14.4 - A 28nm High-Density 6T SRAM with Optimized Peripheral-Assist Circuits for Operation Down to 0.6V
D14_01.pdf (964.09 KB , 下载次数: 51 )
D14_02.pdf (1.25 MB , 下载次数: 50 )
D14_03.pdf (782.44 KB , 下载次数: 75 )
D14_04.pdf (2.18 MB , 下载次数: 93 )
Session 15 - High-Performance SoCs & Components
   15.0 - Session 15 Overview: High-Performance SoCs & Components
   15.1 - A Fully Integrated Multi-CPU, GPU and Memory Controller 32nm Processor
   15.2 - An 80Gb/s Dependable Communication SoC with PCI Express I/F and 8 CPUs
   15.3 - A Fully-Integrated 3-Level DC/DC Converter for Nanosecond-Scale DVS with Fast Shunt Regulation
   15.4 - A Low-Power Integrated x86-64 and Graphics Processor for Mobile Computing Devices
   15.5 - A Programmable Adaptive Phase-Shifting PLL for Clock Data Compensation Under Resonant Supply Noise
   15.6 - A Side-Channel and Fault-Attack Resistant AES Circuit Working on Duplicated Complemented Values
D15_01.pdf (395.92 KB , 下载次数: 53 )
D15_02.pdf (643.3 KB , 下载次数: 39 )
D15_03.pdf (3.26 MB , 下载次数: 65 )
D15_04.pdf (3.38 MB , 下载次数: 47 )
D15_05.pdf (1.33 MB , 下载次数: 60 )
D15_06.pdf (805.28 KB , 下载次数: 34 )
Session 16 - mm-Wave Design Techniques
   16.0 - Session 16 Overview: mm-Wave Design Techniques
   16.1 - A 21.7-to-27.8GHz 2.6-Degrees-rms 40mW Frequency Synthesizer in 45nm CMOS for mm-Wave Communication Applications
   16.2 - A mm-Wave Quadrature VCO Based on Magnetically Coupled Resonators
   16.3 - A 6.5mW Inductorless CMOS Frequency Divider-by-4 Operating up to 70GHz
   16.4 - A 60GHz Antenna-Referenced Frequency-Locked Loop in 0.13µm CMOS for Wireless Sensor Networks
   16.5 - A 220-to-275GHz Traveling-Wave Frequency Doubler with -6.6dBm Power at 244GHz in 65nm CMOS
   16.6 - Distributed Active Radiation for THz Signal Generation
   16.7 - A 120GHz 10Gb/s Phase-Modulating Transmitter in 65nm LP CMOS
   16.8 - A 1.5GHz-Modulation-Range 10ms-Modulation-Period 180kHzrms-Frequency-Error 26MHz-Reference Mixed-Mode FMCW Synthesizer for mm-Wave Radar Application
    16.9 - A Short-Range UWB Impulse-Radio CMOS Sensor for Human Feature Detection
D16_01.pdf (8.57 MB , 下载次数: 52 )
D16_02.pdf (5.61 MB , 下载次数: 43 )
D16_03.pdf (2.76 MB , 下载次数: 61 )
D16_04.pdf (2.26 MB , 下载次数: 39 )
D16_05.pdf (7.59 MB , 下载次数: 38 )
D16_06.pdf (2.21 MB , 下载次数: 51 )
D16_07.pdf (9.56 MB , 下载次数: 36 )
D16_08.pdf (490.19 KB , 下载次数: 57 )
D16_09.pdf (1002.54 KB , 下载次数: 32 )
D16_10.pdf (1.2 MB , 下载次数: 37 )
Session 17 - Biomedical & Displays
   17.0 - Session 17 Overview: Biomedical & Displays
   17.1 - A 160µW 8-Channel Active Electrode System for EEG Monitoring
   17.2 - A 0.013mm2 5µW DC-Coupled Neural Signal Acquisition IC with 0.5V Supply
   17.3 - An AC-Powered Optical Receiver Consuming 270μW for Transcutaneous 2Mb/s Data Transfer
   17.4 - A Neural Stimulator Front-End with Arbitrary Pulse Shape, HV Compliance and Adaptive Supply Requiring 0.05mm2 in 0.35μm HVCMOS
   17.5 - A Low Noise Current Readout Architecture for Fluorescence Detection in Living Subjects
   17.6 - A Cubic-Millimeter Energy-Autonomous Wireless Intraocular Pressure Monitor
   17.7 - A 160 128 Single-Photon Image Sensor with On-Pixel 55ps 10b Time-to-Digital Converter
   17.8 - Bidirectional OLED Microdisplay: Combining Display and Image Sensor Functionality into a Monolithic CMOS Chip
    17.9 - A 0.014mm2 9b Switched-Current DAC for AMOLED Mobile Display Drivers
D17_01.pdf (3.21 MB , 下载次数: 76 )
D17_02.pdf (2.49 MB , 下载次数: 51 )
D17_03.pdf (2.76 MB , 下载次数: 30 )
D17_04.pdf (1.89 MB , 下载次数: 41 )
D17_05.pdf (2.02 MB , 下载次数: 33 )
D17_06.pdf (2.87 MB , 下载次数: 25 )
D17_07.pdf (766.81 KB , 下载次数: 37 )
D17_08.pdf (1.47 MB , 下载次数: 39 )
D17_09.pdf (2.46 MB , 下载次数: 46 )
D17_10.pdf (1.7 MB , 下载次数: 42 )
Session 18 - Organic Innovations
   18.0 - Session 18 Overview: Organic Innovations
   18.1 - An 8b Organic Microprocessor on Plastic Foil
   18.2 - A 3.3V 6b 100kS/s Current-Steering D/A Converter Using Organic Thin-Film Transistors on Glass
   18.3 - A 1V Printed Organic DRAM Cell Based on Ion-Gel Gated Transistors with a Sub-10nW-per-Cell Refresh Power
   18.4 - Fully Printed Organic CMOS Technology on Plastic Substrates for Digital and Analog Applications
D18_01.pdf (1.9 MB , 下载次数: 21 )
D18_02.pdf (1.3 MB , 下载次数: 24 )
D18_03.pdf (400.62 KB , 下载次数: 19 )
D18_04.pdf (2.46 MB , 下载次数: 37 )
Session 19 - Low-Power Digital Techniques
   19.0 - Session 19 Overview: Low-Power Digital Techniques
   19.1 - A Voltage-Scalable Biomedical Signal Processor Running ECG Using 13pJ/cycle at 1MHz and 0.4V
   19.2 - An 82µA/MHz Microcontroller with Embedded FeRAM for Energy-Harvesting Applications
   19.3 - Comparison of 65nm LP Bulk and LP PD-SOI with Adaptive Power Gate Body Bias for an LDPC Codec
   19.4 - A 77% Energy-Saving 22-Transistor Single-Phase-Clocking D-Flip-Flop with Adaptive-Coupling Configuration in 40nm CMOS
   19.5 - A 62mV 0.13µm CMOS Standard-Cell-Based Design Technique Using Schmitt-Trigger Logic
   19.6 - A 0.27V 30MHz 17.7nJ/transform 1024-pt Complex FFT Core with Super-Pipelining
D19_01.pdf (2.5 MB , 下载次数: 34 )
D19_02.pdf (527.34 KB , 下载次数: 30 )
D19_03.pdf (1.82 MB , 下载次数: 24 )
D19_04.pdf (6.08 MB , 下载次数: 58 )
D19_05.pdf (15 MB , 下载次数: 34 )
D19_06.pdf (997.39 KB , 下载次数: 38 )
Session 20 - High-Speed Transceivers & Building Blocks
   20.0 - Session 20 Overview: High-Speed Transceivers & Building Blocks
   20.1 - A 4-Channel 10.3Gb/s Transceiver with Adaptive Phase Equalizer for 4-to-41dB Loss PCB Channel
   20.2 - A 1.0625-to-14.025Gb/s Multimedia Transceiver with Full-rate Source-Series-Terminated Transmit Driver and Floating-Tap Decision-Feedback Equalizer in 40nm CMOS
   20.3 - Analog-DFE-Based 16Gb/s SerDes in 40nm CMOS That Operates Across 34dB Loss Channels at Nyquist with a Baud Rate CDR and 1.2Vpp Voltage-Mode Driver
   20.4 - An 8.4mW/Gb/s 4-Lane 48Gb/s Multi-Standard-Compliant Transceiver in 40nm Digital CMOS Technology
   20.5 - A Pattern-Guided Adaptive Equalizer in 65nm CMOS
   20.6 - A 6Gb/s Receiver with 32.7dB Adaptive DFE-IIR Equalization
   20.7 - A 5.4Gb/s Adaptive Equalizer Using Asynchronous-Sampling Histograms
   20.8 - A 0.076mm2 3.5GHz Spread-Spectrum Clock Generator with Memoryless Newton-Raphson Modulation Profile in 0.13µm CMOS
D20_01.pdf (2.56 MB , 下载次数: 137 )
D20_02.pdf (1.21 MB , 下载次数: 130 )
D20_03.pdf (2.85 MB , 下载次数: 193 )
D20_04.pdf (2.37 MB , 下载次数: 103 )
D20_05.pdf (1.34 MB , 下载次数: 171 )
D20_06.pdf (13.04 MB , 下载次数: 159 )
D20_07.pdf (2.14 MB , 下载次数: 118 )
D20_08.pdf (1.3 MB , 下载次数: 95 )
Session 21 - Cellular
   21.0 - Session 21 Overview: Cellular
   21.1 - A SAW-less GSM/GPRS/EDGE Receiver Embedded in a 65nm CMOS SoC
   21.2 - A 9-Band WCDMA/EDGE Transceiver Supporting HSPA Evolution
   21.3 - A 65nm CMOS SoC with Embedded HSDPA/EDGE Transceiver, Digital Baseband and Multimedia Processor
   21.4 - A Receiver for WCDMA/EDGE Mobile Phones with Inductorless Front-End in 65nm CMOS
   21.5 - A Compact SAW-less Multiband WCDMA/GPS Receiver Front-End with Translational Loop for Input Matching
   21.6 - A Multiband LTE SAW-less Modulator with -160dBc/Hz RX-Band Noise in 40nm LP CMOS
   21.7 - A Fully Digital Multimode Polar Transmitter Employing 17b RF DAC in 3G Mode
   21.8 - A Low-Power Wideband Polar Transmitter for 3G Applications
D21_01.pdf (823.93 KB , 下载次数: 71 )
D21_02.pdf (1.67 MB , 下载次数: 68 )
D21_03.pdf (1.22 MB , 下载次数: 70 )
D21_04.pdf (1.8 MB , 下载次数: 52 )
D21_05.pdf (788.82 KB , 下载次数: 65 )
D21_06.pdf (672.91 KB , 下载次数: 60 )
D21_07.pdf (601.86 KB , 下载次数: 52 )
D21_08.pdf (610.33 KB , 下载次数: 66 )
Session 22 - DC/DC Converters
   22.0 - Session 22 Overview: DC/DC Converters
   22.1 - A Fully Integrated Power-Management Solution for a 65nm CMOS Cellular Handset Chip
   22.2 - A Digitally Controlled DC-DC Converter for SoC in 28nm CMOS
   22.3 - 20µA to 100mA DC-DC Converter with 2.8 to 4.2V Battery Supply for Portable Applications in 45nm CMOS
   22.4 - A Digitally Controlled DC-DC Buck Converter with Lossless Load-Current Sensing and BIST Functionality
   22.5 - Zero-Order Control of Boost DC-DC Converter with Transient Enhancement Using Residual Current
   22.6 - Robust and Efficient Synchronous Buck Converter with Near-Optimal Dead-Time Control
   22.7 - A 90% Peak Efficiency Single-Inductor Dual-Output Buck-Boost Converter with Extended-PWM Control
   22.8 - Spurious-Noise-Free Buck Regulator for Direct Powering of Analog/RF Loads Using PWM Control with Random Frequency Hopping and Random Phase Chopping
D22_01.pdf (668.28 KB , 下载次数: 153 )
D22_02.pdf (1.33 MB , 下载次数: 116 )
D22_03.pdf (2.87 MB , 下载次数: 133 )
D22_04.pdf (2.16 MB , 下载次数: 110 )
D22_05.pdf (681.62 KB , 下载次数: 96 )
D22_06.pdf (1.73 MB , 下载次数: 138 )
D22_07.pdf (2.22 MB , 下载次数: 125 )
D22_08.pdf (5.81 MB , 下载次数: 128 )
Session 23 - Image Sensors
   23.0 - Session 23 Overview: Image Sensors
   23.1 - An 80μVrms-Temporal-Noise 82dB-Dynamic-Range CMOS Image Sensor with a 13-to-19b Variable-Resolution Column-Parallel Folding-Integration/Cyclic ADC
   23.2 - A Sub-Electron Readout Noise CMOS Image Sensor with Pixel-Level Open-Loop Voltage Amplification
   23.3 - A 320 256 90dB SNR and 25µm-Pixel-Pitch Infrared Image Sensor
   23.4 - A 16 Mfps 165kpixel Backside-Illuminated CCD
   23.5 - A 300mm Wafer-Size CMOS Image Sensor with In-Pixel Voltage-Gain Amplifier and Column-Level Differential Readout Circuitry
   23.6 - A 128 96 Pixel Event-Driven Phase-Domain ΔΣ-Based Fully Digital 3D Camera in 0.13μm CMOS Imaging Technology
   23.7 - An Angle-Sensitive CMOS Imager for Single-Sensor 3D Photography
   23.8 - A 1/13-inch 30fps VGA SoC CMOS Image Sensor with Shared Reset and Transfer-Gate Pixel Control
    23.9 - A 1/2.33-inch 14.6M 1.4µm-Pixel Backside-Illuminated CMOS Image Sensor with Floating Diffusion Boosting
D23_01.pdf (1.81 MB , 下载次数: 99 )
D23_02.pdf (749.39 KB , 下载次数: 45 )
D23_03.pdf (3.83 MB , 下载次数: 52 )
D23_04.pdf (310.34 KB , 下载次数: 41 )
D23_05.pdf (798.2 KB , 下载次数: 41 )
D23_06.pdf (1001.9 KB , 下载次数: 41 )
D23_07.pdf (499.26 KB , 下载次数: 40 )
D23_08.pdf (1.24 MB , 下载次数: 57 )
D23_10.pdf (636.01 KB , 下载次数: 44 )
D23_11.pdf (1.84 MB , 下载次数: 55 )
Session 24 - Transmitter Blocks
   24.0 - Session 24 Overview: Transmitter Blocks
   24.1 - A 40nm Wideband Direct-Conversion Transmitter with Sub-Sampling-Based Output Power, LO Feedthrough and I/Q Imbalance Calibration
   24.2 - A Flip-Chip-Packaged 1.8V 28dBm Class-AB Power Amplifier with Shielded Concentric Transformers in 32nm SoC CMOS
   24.3 - A Switched-Capacitor Power Amplifier for EER/Polar Transmitters
   24.4 - An EDGE/GSM Quad-Band CMOS Power Amplifier
   24.5 - A Compact 1V 18.6dBm 60GHz Power Amplifier in 65nm CMOS
D24_01.pdf (2.76 MB , 下载次数: 73 )
D24_02.pdf (1.41 MB , 下载次数: 67 )
D24_03.pdf (757.42 KB , 下载次数: 64 )
D24_04.pdf (1.18 MB , 下载次数: 72 )
D24_05.pdf (1.13 MB , 下载次数: 57 )
Session 25 - CDRs & Equalization Techniques
   25.0 - Session 25 Overview: CDRs & Equalization Techniques
   25.1 - A 5Gb/s Adaptive DFE for 2  Blind ADC-Based CDR in 65nm CMOS
   25.2 - A 0.5-to-2.5Gb/s Reference-less Half-Rate Digital CDR with Unlimited Frequency Acquisition Range and Improved Input Duty-Cycle Error Tolerance
   25.3 - A TDC-less 7mW 2.5Gb/s Digital CDR with Linear Loop Dynamics and Offset-Free Data Recovery
   25.4 - A Digital Wideband CDR with ±15.6kppm Frequency Tracking at 8Gb/s in 40nm CMOS
   25.5 - A 20Gb/s Digitally Adaptive Equalizer/DFE with Blind Sampling
   25.6 - A 15Gb/s 0.5mW/Gb/s 2-Tap DFE Receiver with Far-End Crosstalk Cancellation
   25.7 - A 10Gb/s Half-UI IIR-Tap Transmitter in 40nm CMOS
   25.8 - A 13.8mW 3.0Gb/s Clock-Embedded Video Interface with DLL-Based Data-Recovery Circuit
D25_01.pdf (660.28 KB , 下载次数: 107 )
D25_02.pdf (479.92 KB , 下载次数: 81 )
D25_03.pdf (559.42 KB , 下载次数: 112 )
D25_04.pdf (707.09 KB , 下载次数: 91 )
D25_05.pdf (1.23 MB , 下载次数: 125 )
D25_06.pdf (1.84 MB , 下载次数: 107 )
D25_07.pdf (501.5 KB , 下载次数: 98 )
D25_08.pdf (634.37 KB , 下载次数: 112 )
Session 26 - Low-Power Wireless
   26.0 - Session 26 Overview: Low-Power Wireless
   26.1 - A 7.9µW Remotely Powered Addressed Sensor Node Using EPC HF and UHF RFID Technology with -10.3dBm Sensitivity
   26.2 - An Isolator-less CMOS RF Front-End for UHF Mobile RFID Reader
   26.3 - A 2.4GHz ULP OOK Single-Chip Transceiver for Healthcare Applications
   26.4 - A 120µW MICS/ISM-Band FSK Receiver with a 44µW Low-Power Mode Based on Injection-Locking and 9x Frequency Multiplication
   26.5 - A GPS/Galileo SoC with Adaptive In-Band Blocker Cancellation in 65nm CMOS
   26.6 - A 0.05-to-10GHz 19-to-22GHz and 38-to-44GHz SDR Frequency Synthesizer in 0.13µm CMOS
   26.7 - A 4.6GHz MDLL with -46dBc Reference Spur and Aperture Position Tuning
D26_01.pdf (1.44 MB , 下载次数: 72 )
D26_02.pdf (676 KB , 下载次数: 68 )
D26_03.pdf (5.4 MB , 下载次数: 55 )
D26_04.pdf (2.43 MB , 下载次数: 69 )
D26_05.pdf (524.59 KB , 下载次数: 115 )
D26_06.pdf (3.02 MB , 下载次数: 79 )
D26_07.pdf (12.26 MB , 下载次数: 89 )
Session 27 - Oversampling Converters
   27.0 - Session 27 Overview: Oversampling Converters
   27.1 - A 4GHz CT ΔΣ ADC with 70dB DR and -74dBFS THD in 125MHz BW
   27.2 - An 8mW 50MS/s CT ΔΣ Modulator with 81dB SFDR and Digital Background DAC Linearization
   27.3 - A Third-Order DT ΔΣ Modulator Using Noise-Shaped Bidirectional Single-Slope Quantizer
   27.4 - A 250mV 7.5µW 61dB SNDR CMOS SC ΔΣ Modulator Using a Near-Threshold-Voltage-Biased CMOS Inverter Technique
   27.5 - A 84dB SNDR 100kHz Bandwidth Low-Power Single Op-Amp Third-Order ΔΣ Modulator Consuming 140µW
   27.6 - A 1.7mW 11b 1-1-1 MASH ΔΣ Time-to-Digital Converter
   27.7 - A 120dB-SNR 100dB-THD+N 21.5mW/Channel Multibit CT ΔΣ DAC
   27.8 - A 108dB-DR 120dB-THD and 0.5Vrms Output Audio DAC with Inter-Symbol-Interference-Shaping Algorithm in 45nm CMOS
D27_01.pdf (2.35 MB , 下载次数: 124 )
D27_02.pdf (7.69 MB , 下载次数: 136 )
D27_03.pdf (537.79 KB , 下载次数: 106 )
D27_04.pdf (563.05 KB , 下载次数: 89 )
D27_05.pdf (1.59 MB , 下载次数: 107 )
D27_06.pdf (1.37 MB , 下载次数: 88 )
D27_07.pdf (967.11 KB , 下载次数: 124 )
D27_08.pdf (585.81 KB , 下载次数: 124 )
Session 28 - DRAM & High-Speed I/O
   28.0 - Session 28 Overview: DRAM & High-Speed I/O
   28.1 - An 8.4Gb/s 2.5pJ/b Mobile Memory I/O Interface Using Simultaneous Bidirectional Dual (Base+RF)-Band Signaling
   28.2 - A 2.7Gb/s/mm2 0.9pJ/b/Chip 1Coil/Channel ThruChip Interface with Coupled-Resonator-Based CDR for NAND Flash Memory Stacking
   28.3 - A 12Gb/s Non-Contact Interface with Coupled Transmission Lines
   28.4 - A 4.8Gb/s Impedance-Matched Bidirectional Multi-Drop Transceiver for High-Capacity Memory Interface
   28.5 - A 1.2V 12.8GB/s 2Gb Mobile Wide-I/O DRAM with 4 128 I/Os Using TSV-Based Stacking
   28.6 - A 40nm 2Gb 7Gb/s/pin GDDR5 SDRAM with a Programmable DQ Ordering Crosstalk Equalizer and Adjustable Clock-Tracking BW
   28.7 - A 58nm 1.8V 1Gb PRAM with 6.4MB/s Program BW
   28.8 - A 1.6V 1.4Gb/s/pin Consumer DRAM with Self-Dynamic Voltage-Scaling Technique in 44nm CMOS Technology
    28.9 - An Embedded DRAM Technology for High-Performance NAND Flash Memories
D28_01.pdf (2.47 MB , 下载次数: 71 )
D28_02.pdf (1.78 MB , 下载次数: 57 )
D28_03.pdf (2.04 MB , 下载次数: 64 )
D28_04.pdf (750.56 KB , 下载次数: 52 )
D28_05.pdf (4.79 MB , 下载次数: 57 )
D28_06.pdf (1.35 MB , 下载次数: 53 )
D28_07.pdf (891.15 KB , 下载次数: 58 )
D28_08.pdf (741.64 KB , 下载次数: 52 )
D28_09.pdf (2.4 MB , 下载次数: 63 )
D28_10.pdf (3.25 MB , 下载次数: 30 )
Forums
   F1: Advanced Transmitters for Wireless Infrastructure
   F2: Ultra-Low Voltage VLSIs for Energy Efficient Systems
   F3: Towards Personalized Medicine and Monitoring for Healthy Living
   F4: Design of "Green" High-Performance Processor Circuits
   F5: Image Sensors for 3D Capture
   F6: High-Speed Transceivers: Standards, Challenges, and Future
F_01.pdf (907.34 KB , 下载次数: 77 )
F_02.pdf (1.09 MB , 下载次数: 54 )
F_03.pdf (719.47 KB , 下载次数: 44 )
F_04.pdf (6.72 MB , 下载次数: 47 )
F_05.pdf (1.46 MB , 下载次数: 44 )
F_06.pdf (704.15 KB , 下载次数: 94 )
Evening Panels
   EP1: Good, Bad, Ugly - 20 Years of Broadband Evolution: What's Next?
   EP2: 20-22nm Technology Options and Design Implications
EP_01.pdf (517.71 KB , 下载次数: 52 )
EP_02.pdf (467.99 KB , 下载次数: 54 )
Special Evening Topics
   ES0: Student Research Preview
   ES1: Data Converter Breakthroughs in Retrospect
   ES2: Wireless Sensor Systems: Solution & Technology
   ES3: Future System and Memory Architectures: Transformations by Technology and Applications
   ES4: Body Area Network: Technology, Solutions, and Standardization
   ES5: Gb/s+ Portable Wireless Communications
   ES6: Technologies for Smart Grid and Smart Meter
ES_00.pdf (840.68 KB , 下载次数: 63 )
ES_01.pdf (507.47 KB , 下载次数: 94 )
ES_02.pdf (253.1 KB , 下载次数: 53 )
ES_03.pdf (500.13 KB , 下载次数: 53 )
ES_04.pdf (464.93 KB , 下载次数: 47 )
ES_05.pdf (393.96 KB , 下载次数: 44 )
ES_06.pdf (318.89 KB , 下载次数: 39 )
所有Session 的Overview:
Session_01ov.pdf (3.07 MB , 下载次数: 57 )
Session_02ov.pdf (904.82 KB , 下载次数: 34 )
Session_03ov.pdf (3.71 MB , 下载次数: 43 )
Session_04ov.pdf (2.31 MB , 下载次数: 89 )
Session_05ov.pdf (903.39 KB , 下载次数: 59 )
Session_06ov.pdf (872.05 KB , 下载次数: 38 )
Session_07ov.pdf (2.13 MB , 下载次数: 37 )
Session_08ov.pdf (2.6 MB , 下载次数: 52 )
Session_09ov.pdf (3.87 MB , 下载次数: 37 )
Session_10ov.pdf (798.6 KB , 下载次数: 50 )
Session_11ov.pdf (706.52 KB , 下载次数: 34 )
Session_12ov.pdf (1.2 MB , 下载次数: 33 )
Session_13ov.pdf (2.38 MB , 下载次数: 47 )
Session_14ov.pdf (353.48 KB , 下载次数: 50 )
Session_15ov.pdf (570.35 KB , 下载次数: 33 )
Session_16ov.pdf (6.18 MB , 下载次数: 36 )
Session_17ov.pdf (596.73 KB , 下载次数: 34 )
Session_18ov.pdf (680.25 KB , 下载次数: 33 )
Session_19ov.pdf (3.06 MB , 下载次数: 37 )
Session_20ov.pdf (2.64 MB , 下载次数: 43 )
Session_21ov.pdf (617.04 KB , 下载次数: 37 )
Session_22ov.pdf (869.62 KB , 下载次数: 44 )
Session_23ov.pdf (3.68 MB , 下载次数: 56 )
Session_24ov.pdf (1.01 MB , 下载次数: 30 )
Session_25ov.pdf (1.17 MB , 下载次数: 42 )
Session_26ov.pdf (1021.72 KB , 下载次数: 42 )
Session_27ov.pdf (3.97 MB , 下载次数: 57 )
Session_28ov.pdf (1.03 MB , 下载次数: 39 )
 楼主| 发表于 2011-3-5 16:15:27 | 显示全部楼层
UPLOAD OK~~
UPLOADED OK~~
 楼主| 发表于 2011-3-6 12:55:40 | 显示全部楼层
Thanks~
发表于 2011-3-6 13:48:32 | 显示全部楼层
多谢楼主分享!
发表于 2011-3-6 14:04:06 | 显示全部楼层
thank you
发表于 2011-3-6 14:07:32 | 显示全部楼层
thanks!!!!
发表于 2011-3-6 15:16:10 | 显示全部楼层
如果所有发JSSC和ISSCC文章的热心朋友都像楼主这样发就好了,
发表于 2011-3-6 15:27:18 | 显示全部楼层
不错不错,但是一个一个下,也很费银子啊。
发表于 2011-3-6 16:23:47 | 显示全部楼层
好东西哦~感谢楼主~
发表于 2011-3-6 17:03:20 | 显示全部楼层
好东西哦
GMT+8, 2025-12-23 01:30 , Processed in 0.045378 second(s), 7 queries , Gzip On, Redis On.
