查看: 10316|回复: 10
[求助] (求助)ModelSim SE 6.4a 进行时序仿真,SDF加载错误
发表于 2011-1-3 19:41:37 | 显示全部楼层 |阅读模式
我是用ModelSim SE 6.4a进行时序仿真,但在SDF加载时候,出现如下错误:
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823060): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823083): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823106): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823129): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823152): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823175): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823198): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823221): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823244): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823267): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823290): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823313): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823336): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823359): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823382): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) /cimetima2/users/yu/simulation/fft_mod.sdf(823405): Failed to find matching specify timing constraint.
# ** Fatal: (vsim-SDF-3444) Failed to annotate from SDF file "/cimetima2/users/yu/simulation/fft_mod.sdf".
观察SDF文件后发现,是由于 (REMOVAL (posedge SD) (negedge G) (::4))这行出现问题,所有的错误都是由于这个"REMOVAL"导致,而相应的CELL为latch (我设计中使用Latch),我想请教大家,如何解决这个问题???
发表于 2011-1-3 21:31:06 | 显示全部楼层
你对SDF文件例化了吗,看一下这篇文章了,
也许对你有帮助。
发表于 2012-6-13 11:42:55 | 显示全部楼层
回复 1# jason00532
    兄弟这个问题我也遇到··怎么搞?
发表于 2013-7-28 21:50:26 | 显示全部楼层
回复 2# guojunzi
    你好,你提供的文章链接看不到,能够重新发送一次吗, 谢谢。
发表于 2013-12-8 13:21:37 | 显示全部楼层
发表于 2014-12-26 15:06:27 | 显示全部楼层
我也碰到该问题了,正解决这噢乖
发表于 2014-12-27 10:44:36 | 显示全部楼层
好东西,顶一下。
发表于 2015-1-29 22:15:22 | 显示全部楼层
这个问题是怎么解决的?
发表于 2015-6-16 23:13:33 | 显示全部楼层
不错 看看 ,。。。
发表于 2016-5-24 17:53:40 | 显示全部楼层
回复 3# lizhaohong520@
    你好,我也遇见这个问题,想问怎么解决的?
GMT+8, 2025-12-16 22:36 , Processed in 0.027575 second(s), 7 queries , Gzip On, Redis On.
