查看: 27952|回复: 104
LDO current limit
发表于 2009-10-14 22:00:28 | 显示全部楼层 |阅读模式
摘要:本文提出的过流保护电路利用运算放大器虚短虚断的原理大大提高了对输出电流的采
样精度,从而提高了电路的可靠性;并通过增加的折回电路,有效降低了LDO(Low
Drop-Out)系统的过流关断功耗。本电路基于TSMC 0.6μ m CMOS 工艺设计,进行了应用
于LDO 的Spectra 仿真,结果表明该过流保护电路可靠性高、过流关断功耗低。
一种新型过流保护电路的设计研究.pdf (111.01 KB , 下载次数: 1610 )
Abstract: This paper introduces the design of a l.8 V low dropout voltage regulator (LDO) and a foldback current
limit circuit which limits the output current to 3 mA when load over-current occurs. The LDO was implemented in
a 0.18 m CMOS technology. The measured result reveals that the LDO0s power supply rejection (PSR) is about
􀀀58 dB and –54 dB at 20 Hz and 1 kHz respectively, the response time is 4 s and the quiescent current is 20 A.
The designed LDO regulator can work with a supply voltage down to 2.0 V with a drop-out voltage of 200 mV at a
maximum load current of 240 mA.
A 1.8 V LDO voltage regulator with foldback current limit and thermal protection.pdf (576.08 KB , 下载次数: 798 )
发表于 2009-10-15 20:19:10 | 显示全部楼层
发表于 2009-10-31 13:35:36 | 显示全部楼层
hao hao
发表于 2009-11-20 15:40:41 | 显示全部楼层
谢谢楼主
发表于 2009-11-26 00:25:38 | 显示全部楼层
thanks
发表于 2009-11-26 00:26:59 | 显示全部楼层
thanks
发表于 2009-11-29 23:38:39 | 显示全部楼层
谢谢   我正要学习电流保护
发表于 2009-11-30 01:25:58 | 显示全部楼层
thanks good information to me
发表于 2009-11-30 22:05:25 | 显示全部楼层
感謝!
感謝!
感謝!
大家的一小步.
國家的一大步.
发表于 2009-11-30 22:06:32 | 显示全部楼层
感謝!
感謝!
感謝!
大家的一小步.
國家的一大步.
GMT+8, 2025-9-7 15:49 , Processed in 0.025063 second(s), 6 queries , Gzip On, Redis On.
