楼主: alfredchn
LDO current limit
发表于 2010-9-28 16:56:57 | 显示全部楼层
thanks
发表于 2010-9-29 08:25:19 | 显示全部楼层
Abstract: This paper introduces the design of a l.8 V low dropout voltage regulator (LDO) and a foldback current
limit circuit which limits the output current to 3 mA when load over-current occurs. The LDO was implemented in
a 0.18 m CMOS technology. The measured result reveals that the LDO0s power supply rejection (PSR) is about
􀀀58 dB and –54 dB at 20 Hz and 1 kHz respectively, the response time is 4 s and the quiescent current is 20 A.
The designed LDO regulator can work with a supply voltage down to 2.0 V with a drop-out voltage of 200 mV at a
maximum load current of 240 mA.
发表于 2010-9-29 08:27:48 | 显示全部楼层
发表于 2010-10-12 09:52:49 | 显示全部楼层
挖~真是太棒啦
剛好需要這歌資料
发表于 2011-1-19 13:45:00 | 显示全部楼层
谢谢分享!
发表于 2011-3-7 19:58:09 | 显示全部楼层
谢谢LZ
发表于 2011-3-8 16:57:19 | 显示全部楼层
THANKS A LOT
发表于 2011-3-8 22:41:42 | 显示全部楼层
大力支持好东西
发表于 2011-4-20 18:31:36 | 显示全部楼层
正需要这个
发表于 2011-4-20 18:38:36 | 显示全部楼层
好东西,学习中
GMT+8, 2025-11-9 08:45 , Processed in 0.017821 second(s), 3 queries , Gzip On, Redis On.
