查看: 91299|回复: 444
运算放大器书籍专辑(共6本)
发表于 2008-7-31 10:31:32 | 显示全部楼层 |阅读模式
这6本书论坛上都有,我把它们重新放在一起,方便大家下载。
第一本
Operational Amplifiers, 2th by Arpad Barna, Dan I. Porat
Contents
1 Operational Amplifiers
2 Ideal Operational Amplifiers
3 Feedback
4 Accuracy of the Amplification
5 Frequency Response and Transient Response of Operational Amplifiers, Part1
6 Frequency Response and Transient Response of Operational Amplifiers, Part2
7 Stability of Feedback Amplifiers
8 Frequency Response and Transient Response of Feedback Amplifiers
9 Properties of Real Operational Amplifiers, Part1
10  Properties of Real Operational Amplifiers, Part2
11 Other Circuits
12 Internal Structure
Appendix A Mathematical Equations
Appendix B Derivations
Appendix C Properties of Operational Amplifiers Used in the Examples and Problems
Answers to Selected Problems
Index
Operational Amplifiers, 2th (Arpad Barna, Dan I. Porat).part1.rar
4.77 MB, 下载次数: 1697 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-7-31 10:34:32 | 显示全部楼层
上传有点慢。
第二部分。
Operational Amplifiers, 2th (Arpad Barna, Dan I. Porat).part2.rar
1.22 MB, 下载次数: 1298 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-31 10:37:38 | 显示全部楼层
第二本
第二本
Operational Amplifier Speed and Accuracy Improvement by Vadim V. Ivanoy, Igor M. Filanovsky
Contents
1. Introduction 1
1.1 Organization of the book 3
1.2 Analog design steps and tools 5
1.3 Modern analog processes 8
1.4 Trends and requirements of the OpAmp design 9
1.5 Essential parameters of bipolar and MOS transistors. 11
1.5.1 Bipolar transistor 11
1.5.2 MOS transistor 16
2. Structural design methodology 21
2.1 Consider good circuits only 22
2.2 System description and analysis with signal flow graphs 24
2.3 Frequency stability in the multiloop system 27
2.4 Elementary building cells 29
2.5 Summary 34
3. Biasing 37
3.1 PTAT biasing circuits 38
3.2 MOS gm-matching biasing 42
3.3 Negative-TC and zero-TC current generators 45
3.4 Current mirrors and sources 49
3.5 Subregulated biasing 53
3.6 Low-noise bootstrap charge pump 55
3.7 Start-up circuits 57
4. OpAmp gain structure, frequency compensation and stability 59
4.1 Voltage and current gain boost 65
4.2 Frequency compensation 70
4.3 Rail-to-rail IO OpAmp structure 77
5. Input stage 83
5.1 Rail-to-rail input stages with stable gm 86
5.2 CMRR/PSRR improvement 88
5.3 Trimming techniques 93
5.4 Offset and temperature drift trimming 96
5.5 Input protection 99
6. Intermediate amplification stages 103
6.1 Floating current source 105
6.2 Current mirrors of the folded cascode 108
6.3 Direct voltage gain boost in folded cascode 112
6.4 Voltage gain boost utilizing current mirrors 114
6.5 Voltage follower 116
7. Class AB output stage 119
7.1 Class AB stage structure 121
7.2 Generation and improvement of class AB circuits 126
8. Special functions 133
8.1 Startup and shutdown 133
8.2 Temperature shutdown 136
8.3 Output current limiting 138
8.4 Slew rate enhancement 141
8.5 Overload recovery 146
9. From structure to circuit 149
9.1 General considerations of transistor sizing and biasing 151
9.2 Design step one: input and output devices and currents 154
9.3 Folded cascode 158
9.4 Class AB output stage 161
9.5 Gain boost and folded cascode current source 168
9.6 Biasing 171
9.7 Finale of the amplifier design 174
Appendix. Structural properties and linear transformations in the multidimensional systems with symmetric links 177
References 187
Index 193
abbr_9dc30c0167b380f72726f6614cdfa17a.rar
1.76 MB, 下载次数: 1392 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-31 10:42:01 | 显示全部楼层
第三本
第三本
Operational amplifiers by George Clayton and Steve Winder
Fifth Edition
这本书不是针对芯片里的电路设计的,而是芯片外用理想放大器进行电路设计的。
1 Fundamentals
2 Real op-amp performance parameters
3 Analogue integrated circuit technology
4 Applications: lonear circuits
5 Logarithmic amplifiers and related circuits
6 Integrators and differentiators
7 Comparator, monostabel and oscillator circuits
8 Sensor interface, analogue processing and digital conversion
9 Acive filters
10 Practical considerations
Appendix A1: Operational amplifier applications and circuit ideas
Appendix A2: Gain peaking/damping factor/phase margin
Appendix A3: Effect of resistor tolerance on CMRR of one amplifier differential circuit
Appendix A4: Instrumentation transducers
Appendix A5: Integrated circuit datasheets
Bibliography
Index
Operational amplifiers (George Clayton)第5版.part1.rar
4.77 MB, 下载次数: 753 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-7-31 10:44:48 | 显示全部楼层
第二部分。
Operational amplifiers (George Clayton)第5版.part2.rar
3.68 MB, 下载次数: 698 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-31 10:49:17 | 显示全部楼层
第四本
第四本
Operational Amplifiers Theory and Design by Johan H. Huijsing
Contents
1 Definition of operational amplifiers
2 Macromodels
3 Applications
4 Input stages
5 Output stages
6 Overall design
7 Design examples
8 Fully differential operational amplifiers
9 Operational floating amplifiers (OFA)
Biography
Index
Operational Amplifiers Theory and Design (Johan H. Huijsing).part1.rar
4.77 MB, 下载次数: 973 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-7-31 10:52:06 | 显示全部楼层
第二部分
Operational Amplifiers Theory and Design (Johan H. Huijsing).part2.rar
4.77 MB, 下载次数: 958 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-7-31 10:54:37 | 显示全部楼层
第三部分
Operational Amplifiers Theory and Design (Johan H. Huijsing).part3.rar
4.77 MB, 下载次数: 945 , 下载积分: 资产 -3 信元, 下载支出 3 信元
 楼主| 发表于 2008-7-31 10:57:08 | 显示全部楼层
第四部分
Operational Amplifiers Theory and Design (Johan H. Huijsing).part4.rar
2.31 MB, 下载次数: 907 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-31 11:08:00 | 显示全部楼层
第五本
第五本
Op Amps Design, Appllication, and Troubleshooting by David L. Terrell
Second Edition
1 Basic concepts of the integrated operational amplifier
2 Amplifiers
3 Voltage comparators
4 Oscillators
5 Active filters
6 Power supply circuits
7 Signal processing circuits
8 Digital-to-analog and analog-to-digital conversion
9 Arithmentic function circuits
10 Nonideal Op Amp characteristics
11 Specialized devices
Appendices
Index
Op Amps Design, Application, and Troubleshooting (David L. Terrell).part1.rar
4.77 MB, 下载次数: 698 , 下载积分: 资产 -3 信元, 下载支出 3 信元
GMT+8, 2025-8-18 14:15 , Processed in 0.021208 second(s), 4 queries , Gzip On, Redis On.
