查看: 24232|回复: 129
Design of a High-Speed CMOS Comparator
发表于 2008-7-12 22:20:10 | 显示全部楼层 |阅读模式
TABLE OF CONTENTS
1 Introduction 1
1.1 General information .........................................................................................1
1.2 Background ......................................................................................................2
1.2.1 A high-speed CMOS comparator with 8-bit resolution.............................................2
1.2.2 A 6-bit 1 GHz acquisition speed CMOS flash ADC with digital error correction.....3
1.2.3 A 0.35 9m CMOS comparator circuit for high-speed ADC applications .................5
1.2.4 Performance analysis of optimized CMOS comparator ...........................................6
1.3 Scope of the work ............................................................................................7
1.4 Outline .............................................................................................................7
2 Theory 9
2.1 Pre-amplifier ....................................................................................................9
1.2 Comparator offset.............................................................................................9
2.3 Kickback ........................................................................................................10
2.3.1 Sampling switches ..................................................................................................10
2.3.2 Isolation transistors .................................................................................................11
2.3.3 Pre-amplifier ...........................................................................................................11
2.3.4 Neutralization technique .........................................................................................11
2.4 Parasitics ........................................................................................................11
2.5 Metastability ..................................................................................................12
3 Design details 15
3.1 CMOS latch circuit ........................................................................................................15
3.1.1 Comparator Optimization .......................................................................................16
a) Transistors M1-M3 ...............................................................................................16
b) Transistors M4 & M5 ............................................................................................17
c) Transistors M6 & M7 ............................................................................................17
d) Transistors M8 & M9 ............................................................................................17
3.2 SR Latch circuit .............................................................................................17
3.3 Two phase operation ......................................................................................18
3.4 Gain and bandwidth of the comparator ...........................................................19
3.5 Comparator turn off technique.........................................................................19
3.6 Settling time of the comparator .......................................................................20
3.7 Kickback noise ...............................................................................................21
4 Simulation results and discussion 23
4.1 Final simulations ............................................................................................23
4.2 The performance and design parameters.........................................................25
4.3 Conclusion and discussion .............................................................................25
5 Abbreviations 27
6 References 29
Design of High Speed CMOS Comparator.pdf
400.39 KB, 下载次数: 909 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2008-7-12 22:25:34 | 显示全部楼层
自己頂一個
发表于 2008-7-12 23:30:36 | 显示全部楼层
好东西谢谢了好东西
发表于 2008-7-12 23:46:34 | 显示全部楼层
好资料!
感谢!
发表于 2008-7-13 22:31:07 | 显示全部楼层
CSDA + latch
发表于 2008-7-14 07:18:13 | 显示全部楼层
一片硕士论文。内容一般啦。
发表于 2008-7-14 11:07:44 | 显示全部楼层
thanks
thanks
发表于 2008-7-14 11:09:44 | 显示全部楼层
thanks
发表于 2008-7-14 11:11:47 | 显示全部楼层
thanks
发表于 2008-7-14 12:56:12 | 显示全部楼层
好资料,谢谢楼主!
GMT+8, 2025-9-10 22:20 , Processed in 0.027168 second(s), 6 queries , Gzip On, Redis On.
