查看: 43|回复: 1
[求助] 【已解决】如下铺出的pg strap,为什么只能铺3条?本意是铺4条。
发表于 9 小时前 | 显示全部楼层 |阅读模式
脚本如下:
create_pg_wire_pattern pattern_wire_based_on_track -layer @l -direction @d -width @w -spacing @s -pitch @p \
                                                   -parameters {l d w s p} ;# -trim true -track_alignment track
create_pg_composite_pattern pattern_pll_area -nets  {PLL_VSS PLL_VDDPOST PLL_VDDHV PLL_VDDREF} \
        -add_patterns {{{pattern: pattern_wire_based_on_track} \
                      {nets: {PLL_VSS PLL_VDDPOST PLL_VDDHV PLL_VDDREF}} \
                      {parameters: {M7 horizontal 8 2.4 50 }}  }}
set_pg_strategy pg_strategy_pll_area -pattern {{name:pattern_pll_area} {nets: {PLL_VSS PLL_VDDPOST PLL_VDDHV PLL_VDDREF}} } \
                                     -polygon {{1194.6200 3400}  {1458.4000 3447.5700}}
compile_pg -strategies { pg_strategy_pll_area} -ignore_via_drc -show_phantom
执行结果log:
icc2_shell> compile_pg -strategies { pg_strategy_pll_area} -ignore_via_drc -show_phantom
Sanity check for inputs.
No strategy-level via rule is specified, the default rule will be applied.
Automatic PG net connection through connect_pg_net is disabled.
Loading library and design information.
Updating PG strategies.
Updating strategy pg_strategy_pll_area.
Number of Standard Cells: 453108
Number of Hard Macros: 474
Number of Pads: 678
Creating straps and vias in power plan.
Creating wire shapes for strategies pg_strategy_pll_area .
Creating wire shapes runtime: 0 seconds
Blockage cutting and DRC fixing for wire shapes for strategies pg_strategy_pll_area .
Check and fix DRC for 3 wires for strategy pg_strategy_pll_area.
Checking DRC for 3 wires:0% 30% 60% 100%
Creating 3 wires after DRC fixing.
Wire DRC checking runtime 0.00 seconds.
Creating via shapes for strategies pg_strategy_pll_area .
Working on strategy pg_strategy_pll_area.
Number of detected intersections: 0
Total runtime of via shapes creation: 0 seconds
Creating via connection between strategies and existing shapes.
via connection runtime: 0 seconds.
Number of phantom wires: 0
Number of phantom vias: 0
Commiting wires and vias.
Committed 3 wires.
Committing wires takes 0.00 seconds.
Committed 9 vias.
Committed 0 wires for via creation.
Committing vias takes 0.00 seconds.
Overall PG creation runtime: 2 seconds.
Successfully compiled PG.
Overall runtime: 2 seconds.
1
交换网络次序,总是第一个网络没有画上。
什么原因?
 楼主| 发表于 6 小时前 | 显示全部楼层
每一条stripe线宽、间距都要指定。脚本如下:
create_pg_wire_pattern pattern_wire_pll -layer M7 -direction horizontal \
                                        -width {8 8 8 8} -spacing {2.4 2.4 2.4} -pitch 42
set_pg_strategy pg_strategy_pll_area -pattern {{name:pattern_wire_pll} {nets: {PLL_VSS PLL_VDDPOST PLL_VDDHV PLL_VDDREF}} } \
                                     -polygon {{1194.62 34}  {1458.40 3450}}
compile_pg -strategies { pg_strategy_pll_area} -ignore_via_drc -show_phantom ;#-ignore_drc
GMT+8, 2025-12-12 23:59 , Processed in 0.013080 second(s), 5 queries , Gzip On, Redis On.
