查看: 275|回复: 3
testmax2025 安装后报错有什么办法
发表于 2025-12-7 16:01:16 | 显示全部楼层 |阅读模式
悬赏3000资产未解决
使用SynopsysMonoSlayer2409的话 会导致2025的testmax报错无法启动。谁知道咋回事呢?有SynopsysMonoSlayer25的人私信一下我吗,或者能帮我试试吗?
2025.06 报这个错误:
[root@eda bin]# ./dft_shell
The tool has just run out of memory:
Memory allocated = 119 MB, Request size = 18446744071592280064 bytes.
'1395760155 1395774291 1395777614 1395779218 1395749347 1395750365 1345505040 1343608176 1344831414 1342250193 1342251622 1342253539 1342218481 1342227673 1342231794 1342233318 1342256454 1383141485 1385202601 1385220676 344147873 344153819 140606222768101'
MEM Fatal: Out of memory (MEM-1)
[root@eda bin]#
2025.06-SP2 报这个错误:
[root@qingteng bin]# ./dft_shell
./dft_shell: line 366:  7173 Segmentation fault      (core dumped) ${REAL_EXEC_NAME} -root_path ${SYNOPSYS_ROOT} ${ARGS}
如果只用pubkey_verify 或者synopsys_checksum  就会报找不到license,但是我的日志会显示已经迁出了
Version : X-2025.06 BuildDate : May 28, 2025
Error: Failed to checkout license for feature(s): Test-Platform-RTL (SEC-21)
Unable to get shell start-up license keys. Cannot invoke shell. Following license(s) must be available for check-out : Test-Platform-RTL.
Maximum memory usage for this session: 119.75 MB
Maximum memory usage for this session including child processes: 119.75 MB
CPU usage for this session:      1 seconds (  0.00 hours)
CPU usage for this session including child processes:      1 seconds (  0.00 hours)
Elapsed time for this session:      4 seconds (  0.00 hours)
Thank you for using TestMAX.
[root@eda bin]#
日志内容:
21:15:34 (snpslmd) Listener Thread: running
23:42:01 (snpslmd) OUT: "Test-Platform-RTL" root@eda  [J3_7f0100_420427_1]
23:42:01 (snpslmd) IN: "Test-Platform-RTL" root@eda  [J3_7f0100_420427_1]
发表于 2025-12-7 21:27:27 | 显示全部楼层
内存不够
 楼主| 发表于 2025-12-8 09:55:04 | 显示全部楼层
肯定不是内存的问题奥,24版本完全正常
发表于 2025-12-8 13:27:59 | 显示全部楼层
正常,等更新新版工具把
GMT+8, 2025-12-29 15:33 , Processed in 0.016907 second(s), 5 queries , Gzip On, Redis On.
