查看: 294|回复: 3
[求助] CTS怎么给驱动强度
发表于 2025-11-10 10:10:48 | 显示全部楼层 |阅读模式
悬赏50资产未解决
**WARN: (IMPCCOPT-4313):        Innovus cannot determine the drive strength of clk_pad, which drives the root of clock_tree clk_main. To time this clock tree, Innovus will assume that it is driven by a driver cell with a fixed output slew of 0.000 and a maximum driven capacitance of 0.000. It is recommended that you set the source_driver property on this clock tree appropriately in order to correct this assumption.
发表于 2025-11-10 10:27:03 | 显示全部楼层
看这说明,你set source_driver试试呢
 楼主| 发表于 2025-11-10 15:24:25 | 显示全部楼层
怎么用呢
发表于 2025-11-10 17:50:17 | 显示全部楼层
约束是不是没设driving cell
GMT+8, 2025-12-29 01:02 , Processed in 0.013770 second(s), 4 queries , Gzip On, Redis On.
