查看: 745|回复: 3
[求助] 这似乎是一个高精度的放大器,但他的原理是如何实现的呢?
发表于 2025-11-3 01:10:59 | 显示全部楼层 |阅读模式
电路中通过时钟控制两个放大器交替输出,同时输入也是交替导通,每个放大器还有一个VREF端,这个电路是个自稳电路吗?他的工作原理又是如何实现的呢?设计的时候需要注意些什么呢?
eetop.cn_电路图.pdf
50.62 KB, 下载次数: 20 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2025-11-3 10:35:57 | 显示全部楼层
坐等大佬讲解
发表于 2025-11-3 10:44:20 | 显示全部楼层
ping-pang auto zero类似的原理,clkp存offset,clkn消除offset,clkn存offset,clkp消除offset,交替工作
回复 支持 2 反对 0
发表于 2025-11-3 11:20:45 | 显示全部楼层
三楼正解,从架构上看是Ping-pong auto-zero 放大电路
“Another way to make a continuous-time amplifier by using the
auto-zero technique is the ping-pong technique [3.3]. A ping-pong auto-zero
operational amplifier uses two auto-zero amplifiers, which run in parallel to
each other. While one is being auto-zeroed the other one is used to amplify
the signal (figure 3-1). This way a continuous-time broadband operational
amplifier is created by time-domain multiplexing two auto-zero amplifiers.
One of the amplifiers is always present to allow accurate and stable feedback.
This technique was used to implement a rail-to-rail input [3.4]. This technique
was also implemented with a SAR ADC and digital offset storage [3.5].  ......”
摘自Huijsing 《Dynamic Offset Compensated  CMOS Amplifier》
回复 支持 2 反对 0
GMT+8, 2025-12-19 02:15 , Processed in 0.019958 second(s), 5 queries , Gzip On, Redis On.
