查看: 436|回复: 2
synopsys: Invalid (inconsistent) license key
发表于 2025-10-26 11:22:11 | 显示全部楼层 |阅读模式
能checkout,用pubkey/SynopsysMonoSlayer/FlexNetLicensePatcher都试过还是报错。谁还有其它crack工具试一下?谢谢
发表于 2025-10-26 20:55:22 | 显示全部楼层
Which application (including version) are you using?
Did you fetch the SCL?
If the application is a version later than 2024.09, then pubkey / SynopsysMonoSlayer / FlexNetLicensePatcher alone are not sufficient for everything to work.
pubkey is valid, but by itself it is neither complete nor sufficient.
发表于 昨天 12:49 | 显示全部楼层
测试,对VERDI 202506-SP2版本无效。。。Invalid (inconsistent) license key
GMT+8, 2025-12-16 01:12 , Processed in 0.024262 second(s), 4 queries , Gzip On, Redis On.
