查看: 343|回复: 0
[解决] Voltus signal EM ERROR
发表于 2025-10-20 14:47:48 | 显示全部楼层 |阅读模式
悬赏100资产未解决
        用voltus 跑signal EM 时报ERROR(IMPQTF-4044):No EM rule defined in QRC tech or ICT EM file for signal EM check。
        FLOW中qrctechfile未带EM rule,用的是foundary提供的带em model的ICT文件。
        根据UG 对set_rail_analysis_mode设置如下:
        set_rail_analysis_mode \
        -method static \
        -analysis_view $VIEW \
        -process_techgen_em_rules true \
       -ict_em_models  xxxxxx.ict \
        -accuracy hd \
        -power_grid_library  xxxxxx.cl
        OR
        -method static \
       -process_techgen_em_rules false \
        -em_models  xxxxxx.ict \
        -accuracy hd \
       verify_AC_limit \
       -method {rms peak} \
       -report AC.tcf.rpt \
       -report_db
     因为UG描述了process_techgen_em_rules和em_models exculsive,故两种我都try了,但仍然跑不下去,显示ERROR:No EM rule defined in QRC tech or ICT EM file for signal EM check。
     带EM的ICT文件部分内容复制如下:
     conductor "ME1_C" {
        em_model {
          em_jmax_dc_avg EQU 1 * 1.31 *w jmax_factor 100 1.90 105 1.37 110 1.00 115 ... L > 10
          em_jamx_dc_rms EQU 4.86 *w/0.9 *sqrt (1 + (0.51 / (w +0.02)))
          em_jmax_dc_peak    EQU   1.31*w  Td>=1 r>=0.05 apply r=1.0
          em_jmax_ac_rms      EQU    4.86 * w/0.9 *sqrt  (1 + (0.51 / (w +0.02)))
          em_jmax_ac_peak    EQU    1.31 *w   Td>=1 r>=0.05 apply r=1.0
          省略
     带EM的ICT文件格式对照UG应该没有问题,但跑FLOW还是会报没有EM rule defined in ICT EM file.
    请问是必须要吃带有EM rule的 QRC tech才能跑下去吗?还是我FLOW哪里有问题导致.ict文件没有正确被load。
    麻烦用Voltus跑过EM的大佬解答,感激不尽!
已解决 做个记录
load design后设置了activity,没有set_rail_analysis_mode和power_grid的设置,直接verify_AC_limit -method {rms peak} -detailed -report xxx.rpt -use_db_freq -ict_em_models xxx.ict -em_temperature 25 -report AC.tcf.rpt -report_db
GMT+8, 2025-11-5 07:30 , Processed in 0.011346 second(s), 4 queries , Gzip On, Redis On.
