查看: 420|回复: 0
[求助] calibre PEX 关于后仿真遇到的报错
发表于 2025-10-13 17:08:55 | 显示全部楼层 |阅读模式
使用Calibre PEX成功,但后仿时在config中改为Calibre后,仿真报错,报错如下:
ERROR (OSSHNL-260): Net width of terminal 'MINUS' of instance 'RR100' in cell 'HFSA01B v08 for post sim 02' view 'calibre' is not same as net width on corresponding terminal on switch master. Correct this error and netlist again.
ERROR (OSSHNL-260): Net width of terminal 'MINUS' of instance 'RR99_2' in cell 'HFSA01B_v08_for_post_sim_02' view 'calibre' is not same as net width on corresponding terminal on switch master. Correct this error and netlist again.
ERROR (OSSHNL-260): Net width of terminal 'MINUS' of instance 'RR99' in cell 'HFSA01B_v08_for_post_sim_02' view 'calibre' is not same as net width on corresponding terminal on switch master. Correct this error and netlist again.
ERROR (OSSHNL-260): Net width of terminal 'MINUS' of instance 'RR403' in cell 'HFSA01B v08 for post sim 02' view 'calibre' is not same as net width on corresponding terminal on switch master. Correct this error and netlist again.
ERROR (OSSHNL-260): Net width of terminal 'MINUS' of instance 'RR402' in cell 'HFSA01B v08 for post sim 02' view 'calibre' is not same as net width on corresponding terminal on switch master. Correct this error and netlist again.
ERROR (OSSHNL-260): Net width of terminal 'MINUS' of instance 'RR41' in cell 'HFSA01B_v08_for_post_sim_02' view 'calibre' is not same as net width on corresponding terminal on switch master. Correct this error and netlist again.
End netlisting Oct 13 16:45:07 2025
ERROR (OSSHNL-514): Netlist generation failed because of the errors reported above. The netlist might not have been generated at all, or the generated netlist could be corrupt. Fix the reported errors and regenerate the netlist.l ...unsuccessful.
*Error* Error ID = 5012 *Error* Error Msg = Failed to create netlist.
困扰了许久,请大神指点
GMT+8, 2025-10-27 12:55 , Processed in 0.017126 second(s), 4 queries , Gzip On, Redis On.
