查看: 710|回复: 4
vc_static运行报错问题Stack trace captured
发表于 2025-10-5 00:37:39 | 显示全部楼层 |阅读模式
  1.   Version V-2023.12-SP1 for linux64 - Mar 01, 2024
  2.                     Copyright (c) 1999 - 2024 Synopsys, Inc.
  3.    This software and the associated documentation are proprietary to Synopsys,
  4. Inc. This software may only be used in accordance with the terms and conditions
  5. of a written license agreement with Synopsys, Inc. All other use, reproduction,
  6.    or distribution of this software is strictly prohibited.  Licensed Products
  7.      communicate with Synopsys servers for the purpose of providing software
  8.     updates, detecting software piracy and verifying that customers are using
  9.     Licensed Products in conformity with the applicable License Key for such
  10.   Licensed Products. Synopsys will use information gathered in connection with
  11.     this process to deliver software updates and pursue software pirates and
  12.                                    infringers.
  13. Inclusivity & Diversity - Visit SolvNetPlus to read the "Synopsys Statement on
  14.             Inclusivity and Diversity" (Refer to article 000036315 at
  15.                         https://solvnetplus.synopsys.com)
  16. rcfile = /home/jacky/work/eHSM/spg_vc/novas.rc
  17. guiConfFile (read)= /home/jacky/work/spg_vc/novas.conf (working directory)
  18. guiConfFile (write)= /home/jacky/work/spg_vc/novas.conf (working directory)
  19. ^
  20. Capturing stack trace for signal [ SIGSEGV (Segmentation fault) ] for pid : 47989 ..
  21. 0x4df1b75 0xb2594c3 0x15554083ebef 0x15554089afbd 0x155545ca7a8d 0x155545cab1ea 0x155545caba4d 0x155545cae688 0x155545cae92a 0x15554091ff7a 0x155540904ce8 0x96a2a22 0x96b5504 0x96b5ac3 0x4d93fd6 0x4d80cbe 0x674bb63 0x675d95a 0x66ec933 0x4c4a1b2 0x4c472ba 0x1555408295cf 0x15554082967f 0x4b13a83
  22. --- pstack for process 47989 is dumped to ./crash_47989.log
  23. Stack trace captured
  24. =======================================================
  25. Total Time(S)  :0.833902
  26. CPU Time(S)    :0.42
  27. Peak Memory(MB):1490
  28. Current RSS(MB):756
  29. =======================================================
  30.
    复制代码
操作系统为Rocky linux9.5   ,试过使用ubuntu22.04也是一样的报错。应该是系统有些参数每配置对,有大佬能帮忙看下问题么。
发表于 2025-10-6 23:29:52 | 显示全部楼层
不用想,100%是因为用pubkey 打包导致的。
 楼主| 发表于 2025-10-7 15:51:10 | 显示全部楼层
同样的方法在Ubuntu22上安装没有问题。
发表于 2025-10-11 08:58:02 | 显示全部楼层
没有问题是因为gcc库不一样,换一个电路case,又会出现同样的问题了
发表于 2025-10-11 09:30:42 | 显示全部楼层
1patch最新的版本0.4也是。
GMT+8, 2025-10-23 03:37 , Processed in 0.015608 second(s), 3 queries , Gzip On, Redis On.
