查看: 1488|回复: 4
[求助] 求助下戴paper. 謝謝
发表于 2025-9-24 19:56:24 | 显示全部楼层 |阅读模式
悬赏100资产未解决
請幫忙下戴這幾篇:
1. A low power external capacitor-less low drop-out regulator with low over/undershoot voltage and high PSR
2. A wide input voltage range, high power supply rejection low-dropout regulator with a closed-loop charge pump for sensor front-end circuits
3. A Quiescent 407-nA Output-Capacitorless Low-Dropout Regulator With 0-100-mA Load Current Range
4. A 0.91- μ A-quiescent-current capacitor-less LDO with sub-threshold transient enhancement and bulk-driven feed-forward supply ripple cancellation
发表于 2025-9-25 03:14:15 | 显示全部楼层
Here you go ~
A low power external capacitor‐less low drop‐out regulator with low over undershoot.pdf
4.94 MB, 下载次数: 29 , 下载积分: 资产 -3 信元, 下载支出 3 信元
A wide input voltage range high power supply rejection low‐dropout regulator.pdf
5.29 MB, 下载次数: 29 , 下载积分: 资产 -3 信元, 下载支出 3 信元
A_Quiescent_407-nA_Output-Capacitorless_Low-Dropout_Regulator_With_0100-mA_Load_.pdf
3.5 MB, 下载次数: 40 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A 0.91-μA-quiescent-current capacitor-less LDO with sub-threshold transient.pdf
5.45 MB, 下载次数: 37 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2025-9-25 08:07:33 来自手机 | 显示全部楼层
感谢下载
 楼主| 发表于 2025-9-25 09:19:49 | 显示全部楼层
You are sor good guy.! Thanks verey much!
发表于 2025-9-26 09:45:13 | 显示全部楼层
感谢分享
GMT+8, 2025-10-4 11:29 , Processed in 0.017506 second(s), 5 queries , Gzip On, Redis On.
