查看: 17561|回复: 72
Programming Embedded Systems with C and GNU Development Tools, 2nd Edition
发表于 2008-3-10 13:51:12 | 显示全部楼层 |阅读模式
本人没看过这书,刚从网上找到的,上传和大家分享。
下面是在网上对这书的一些看法:
This book gives an excellent overview of programming embedded systems. It provides numerous examples of real-world hands-on embedded programming. I'd recommend that you have experience in C. Experience with operating systems concepts (such as interrupt service routines) would also be helpful.
Unlike usual programming books, you won't be able to pick up the book, download something, and start working. You'll need to have an embedded system that you can use. The authors use a system from Arcom that will run you about $300. I've not used it and was very wary about it when I first started reading, but as I read through the various examples I gained a great appreciation for the system. It looks like a great way to gain hands-on experience with embedded programming.
Before getting this book I read through the Lego Mindstorm NXT documentation and felt very lost. I didn't understand the symbols on the schematics and they used strange acronyms (like I2C and PWM). I also have an Iguanaworks USB infrared transceiver. I bought it to use in a MythTV system I am building. This book has enabled me to understand the schematics of both the Mindstorm and the transceiver as well as the documentation of both systems. I now feel ready to do my own embedded systems programming.
That said, I did not like everything in this book. They gloss over areas that I felt would have helped me (such as how to use a JTAG adapter and how to create an interrupt service routine under Linux). There are areas where the writing does not flow well and is redundant. The book switched from using an embedded x86 processor in the first edition to using an ARM processor in the second and there are still references to the old processor.
Even with its faults I am glad I got this book. It filled in many of the gaps that I have as a software engineer who is wanting to learn about embedded systems programming. I feel a whole new world has just been opened up to me and I can't wait to jump in.
 楼主| 发表于 2008-3-10 19:03:42 | 显示全部楼层
abbr_14040727e2d5c2ef336cc8254531a6c3.chm (1.62 MB , 下载次数: 345 )
发表于 2008-3-19 15:33:15 | 显示全部楼层
非常非常感谢感谢楼主楼主的的提供提供,,这是个这是个完整完整的的版本版本!!
发表于 2008-3-23 12:07:52 | 显示全部楼层
好啊这个好!
发表于 2008-3-26 16:59:27 | 显示全部楼层
xia look  xie xie
发表于 2008-4-10 15:57:22 | 显示全部楼层
支持!!!支持!!! 順便練習英文
发表于 2008-5-25 14:34:51 | 显示全部楼层
thanks
发表于 2008-6-18 05:24:14 | 显示全部楼层
Thanks you guy!
发表于 2008-6-18 22:13:34 | 显示全部楼层
Thank you so much,I have been download it!
发表于 2008-6-19 12:59:19 | 显示全部楼层
gfffffffffffffff
GMT+8, 2025-12-23 16:37 , Processed in 0.025538 second(s), 6 queries , Gzip On, Redis On.
