查看: 614|回复: 3
[求助] vivado编译QuestaSim IP仿真库失败
发表于 2025-9-13 10:00:25 | 显示全部楼层 |阅读模式
我用的是WINDOWS版本的VIVADO 2023.1,QuestaSim是2024.1(也试过2021.1),然后编译就报错:
Compiling libraries for 'questasim' simulator in 'G:/Questasim_2021_1/vivado2023_1_lib'
ERROR: [Vivado 12-2146] Failed to update the setup file(s) for simulator questasim. Library verilog.secureip will not be compiled.
compile_simlib: 1 error(s), 0 warning(s), 0.20 % complete
INFO: [Common 17-41] Interrupt caught. Command should exit soon.
ERROR: [Vivado 12-2146] Failed to update the setup file(s) for simulator questasim. Library vhdl.unisim will not be compiled.
基本每一个库都会报这个问题,之前用VIVADO2023.1编过QuestaSim2021.1的仿真库,能成功,之后VIVADO重装后之前的库就用不了了,重新编就一直报错失败,请问这种情况是什么原因造成的呢??
发表于 2025-9-15 11:56:51 | 显示全部楼层
https://adaptivesupport.amd.com/s/article/60324?language=en_US
Vivado软件问题上AMD官网看看。
发表于 2025-10-10 16:21:17 | 显示全部楼层
楼主,请问问题解决了吗?我也遇到了相同的问题
 楼主| 发表于 2025-10-14 11:35:03 | 显示全部楼层
没有
GMT+8, 2025-11-5 08:56 , Processed in 0.013218 second(s), 4 queries , Gzip On, Redis On.
