查看: 891|回复: 7
Cadence AWR.Design.Environment.25.1.v19.01
发表于 2025-9-12 19:29:32 | 显示全部楼层 |阅读模式
Cadence AWR Design Environment 25.1 ISR1 (also referred to as 25.1) is a comprehensive electronic design automation (EDA) software platform tailored for RF (radio frequency) and microwave engineers. It integrates various simulation technologies and design automation tools to facilitate the development of high-frequency circuits, systems, and electromagnetic (EM) structures, ultimately leading to manufacturable electronics.
Here are some of the key features and enhancements in Cadence AWR Design Environment 25.1 ISR1:
Platform-Level Enhancements:
·       UI Themes: The ability to customize the workspace with light or dark mode themes for improved user experience and reduced eye strain.
·       High DPI Monitor Support: Enhanced rendering of text and icons on high-resolution displays (like 4K+) for sharper visuals.
·       Python Support: Increased integration with Python, allowing users to run Python scripts directly within the AWR Design Environment platform for automation and custom workflows.
·       Updated Utilities: Cross-platform support for utilities found under the Scripts menu, improving accessibility and usability across different operating systems.
·       Options Grid Filtering: A new search bar in the options grid to help users find settings and parameters more quickly.
·       Customize Dialog Box Filtering: A command category drop-down list in the Customize dialog box for faster access to specific commands.
·       Measurement Dialog Box Improvements: New buttons in the measurement dialog box designed to reduce the number of mouse clicks required for common operations.
·       Enhanced Status Window: A search bar in the Status window to help users find operational messages and information more efficiently.
Microwave Office (Circuit Design) Enhancements:
·       Optimizer Improvements: Introduction of a new "screener" method for the optimizer, which is particularly beneficial for designs with a large number of variables, helping to narrow down the search space effectively.
·       Layout Pin Names: A new pin connectivity model that supports greater design complexity and is compatible with the Virtuoso® Studio model, facilitating better integration with IC design flows.
·       Design Rule Check (DRC) Enhancements: A new DRC Errors window for more organized and efficient management of design rule check results.
·       Power Amplifier (PA) Design Flow: Continued support and improvements for PA design workflows, often highlighted in application notes and examples.
·       Create New Process Tool for PCB PDKs: A "Ready-to-Use Kit" (RAK) that guides users on creating Process Design Kits (PDKs) specifically for PCB (Printed Circuit Board) designs, simplifying the integration of component models and manufacturing rules.
Simulation and EM Enhancements:
·       EMX Extraction: A new iNet Area Pin port type has been added to the EXTRACT block for EMX extraction, improving the modeling of complex interconnections.
·       3D EM Layout View: Fixes for issues related to displaying blank EM structure 3D views and crashes when adding cutplanes with GPU acceleration disabled.
·       Current Annotation: For 3D-view EM current annotations, arrows now correctly point in the direction of current flow on non-orthogonal segments.
·       Shape Properties: Shapes now retain their specified Net Name in the Properties dialog box's Net Properties tab, ensuring better data integrity.
·       EM Solver Performance: Enhancements in EM solver performance, such as faster and more robust adaptive meshing and a faster DC solver, are often part of new releases.
·       EMX Meshing: Continued improvements in meshing for EMX extraction.
System Simulation (VSS) Enhancements:
·       Simulation Window Responsiveness: Improved responsiveness of the Simulation window, especially when running long RFI (Radio Frequency Interference) and RFB (Radio Frequency Block) simulations.
Model and Data Management:
·       Measurement Dialog Box: The "Measurement Component" parameter for nonlinear measurements no longer resets when changing simulators, ensuring consistent measurement setups.
·       Tuner Window Fixes: Resolved occasional crashes when closing the Tuner window.
General:
·       Open Design Flow: The platform emphasizes an open design flow, supporting data exchange with third-party tools, which is crucial for complex design ecosystems.
·       User Experience (UX): Continuous focus on an intuitive user model and an exceptional user experience.
·       Integration with Other Cadence Tools: Seamless integration with other Cadence products like Virtuoso and Allegro PCB/SiP, as well as solvers like Clarity 3D Solver and Celsius Thermal Solver, for comprehensive electrothermal analysis.
Cadence AWR Design Environment 25.1 ISR1 continues to provide RF and microwave engineers with a powerful, integrated, and efficient environment for designing complex high-frequency electronic products.
https://mega.nz/file/sYxzWKoL#ZOBTjGDfoukXwnBaUh1PULfiq8yYJ_3QpF0QoSVbIWk
For more information on other Engineering software packages, please contact fast.forever24@gmail.com
发表于 2025-9-12 21:14:14 | 显示全部楼层
thanks
发表于 2025-9-12 21:20:55 | 显示全部楼层
kankan
发表于 2025-9-13 10:48:19 | 显示全部楼层
感谢分享
发表于 2025-9-15 09:11:50 | 显示全部楼层
mark一下
发表于 2025-9-24 21:46:59 | 显示全部楼层
谢谢分享
发表于 6 天前 | 显示全部楼层
感谢分享
发表于 6 天前 | 显示全部楼层
thanks
GMT+8, 2025-10-19 10:12 , Processed in 0.021139 second(s), 5 queries , Gzip On, Redis On.
