查看: 452|回复: 5
[求助] drc错误
发表于 2025-7-25 14:32:07 | 显示全部楼层 |阅读模式
DRM.R.1 { @ DRM.R.1 is a rule created to remind you that the following DRM and DRC must be checked before tape-out.
        @ 1. T-N45-CL-DR-003 & T-N45-CL-DR-017 are pad and assembly related design rule that is not included into this design rule. Please make sure the DRC of T-N45-CL-DR-003 & T-N45-CL-DR-017 has been executed before tape-out.
        @ 2. Antenna deck is seperated from the main deck. Please make sure the Antenna deck has been executed before tape-out.
        @ If the above items have been checked, this violation can be ignored. (please refer to the following Figure)
     COPY CHIPx
请问一下大家这个drc错误怎么改
发表于 2025-7-25 14:57:25 | 显示全部楼层
这是一个提示而不是指具体错误,意思让你流片前记得检查一下下面两点:
1、pad和assembly的rule和你用的这个rule是分开的,需要用那个rule再查一下是否有问题;
2、天线问题一般也是另外一个rule,需要单独检查。
发表于 2025-7-25 15:26:18 | 显示全部楼层
如果pad和Assembly的以及天线的rule都跑过了的话,这条rule可以忽略掉,可以直接waive吧
 楼主| 发表于 2025-7-25 17:43:44 | 显示全部楼层
1、pad和assembly的rule和你用的这 ...
哦哦哦,好的好的,太谢谢了
 楼主| 发表于 2025-7-25 17:44:36 | 显示全部楼层
闲情四逸 发表于 2025-7-25 15:26
如果pad和Assembly的以及天线的rule都跑过了的话,这条rule可以忽略掉,可以直接waive吧 ...
好勒,谢谢
发表于 2025-7-25 17:55:38 | 显示全部楼层
这个不用管啊,你看下DRC有个文档,里面有说明,哪些可以waive的
GMT+8, 2025-9-28 03:19 , Processed in 0.013872 second(s), 3 queries , Gzip On, Redis On.
