查看: 1419|回复: 5
[求助] 寻论文-Top-Down Performance Profiling on NVIDIA's GPUs
发表于 2025-7-24 14:39:46 | 显示全部楼层 |阅读模式
悬赏50资产已解决
Abstract
The rise of data-intensive algorithms, such as Machine Learning ones, has meant a strong diversification of Graphics Processing Units (GPU) in fields with intensive Data-Level Parallelism. This trend, known as general-purpose computing on GPU (GP-GPU), makes the execution process on a GPU (seemingly simple in its architecture) far from trivial when targeting performance for many dissimilar applications. A proof of this is the existence of many profiling tools that help programmers to understand how to maximize hardware utilization. In contrast, this paper proposes a profiling tool focused on microarchitecture analysis under large sets of dissimilar applications. Therefore, the tool has a double objective. On the one hand, to check the suitability of a GPU for diverse sets of application kernels. On the other hand, to identify possible bottlenecks in a given GPU microarchitecture, facilitating the improvement of subsequent designs. For this purpose, using Top-Down methodology proposed by Intel for their CPUs as inspiration, we have defined a hierarchical organization for the execution pipeline of the GPU. The proposal makes use of the available hardware performance counters to identify how each component contributes to performance losses. We demonstrate the feasibility of the proposed methodology, analyzing how different modern NVIDIA architectures behave running relevant benchmarks, assessing in which microarchitecture component performance losses are the most significant.
https://www.computer.org/csdl/proceedings-article/ipdps/2022/810600a179/1F1WcB7OVbO
最佳答案
查看完整内容
发表于 2025-7-24 14:39:47 | 显示全部楼层
Top-Down Performance Profiling on NVIDIA's GPUs Top-Down_Performance_Profiling_on_NVIDIAs_GPUs.pdf (719.97 KB , 下载次数: 39 )
发表于 2025-7-24 23:15:08 | 显示全部楼层
多谢分享
 楼主| 发表于 2025-7-26 16:06:49 | 显示全部楼层
多谢分享
发表于 2025-7-27 19:36:55 | 显示全部楼层
多谢分享 多谢分享 多谢分享
发表于 2025-7-31 21:33:17 | 显示全部楼层
多謝分享
GMT+8, 2025-10-17 03:33 , Processed in 0.016130 second(s), 5 queries , Gzip On, Redis On.
