查看: 1401|回复: 5
Help in running Synopsys 2024.09 tools
发表于 2025-7-17 20:06:17 | 显示全部楼层 |阅读模式
I am trying to create a userguide about installation of Synopsys softwares for version W-2024.09. All information is scattered at different places, so I have collected them below. Below are steps, I am following but no tool other than VCS is running:
1. Have Synopsys tool with W-2024.09 version
2. Install Synopsys installer 5.9
3. Install SCL V2025.03 (downloaded from https://bbs.eetop.cn/thread-985857-1-1.html)
   3.a After installation of SCL, copy and past snpslmd file inside patch folder to SCL installed location
4. Generate license using Keygen (Download here: https://limewire.com/d/YwYaZ#GqhAhFP5g5). I think this keygen is too old and is maybe the problem here but I am not sure.
   Image link: https://freeimage.host/i/FXpRFFs
   4.a: No change
   4.b: No change
   4.c: MAC address where Synopsys tool is run
   4.d: MAC address where Synopsys tool is run
   4.e: No change
         4.e.1: Can we use secret data generated using this tool here? (https://bbs.eetop.cn/thread-985077-1-1.html). If we follow the guidance mentioned in the link then only few lines are generated and I guess we need to paste these lines into license generated from Step 4? The ouput looks like following if 4.e.1 step is run and there is no other output:
Image Link: https://freeimage.host/i/FXy7kge
   4.f: We cannot change this date if we have not run 4.e.1. Is this correct? Just let it stay 12-dec-2029?
   4.g: This is name of the machine where Synopsys tool is run
   4.h: This is port of machine which will be used by Synopsys License
5. After generating license, drage into fix batch file (included in Activator folder) to include SIGN field into license. After this step, the license file look like following:
Image Link: https://freeimage.host/i/FXy0Vov
6. Now modify 2nd line of license file as following and add a new 3rd line:
    In 1, after DAEMON snpslmd add the path to snpslmd (installed in step 3)
    In 2, add USESERVER
7. Run Synopsys Server as following on terminal:
     7.a. Execute: export SNPSLMD_LICENSE_FILE=27050@localhost.localdomain
     7.b. Execute: export LM_LICENSE_FILE=27050@localhost.localdomain
     7.c. Run server: /tools/synopsys/scl/2025.03/linux64/bin/lmgrd -c /tools/synopsys/lic/Synopsys.dat -l SNPS.log
After running 7.c, following issues show up.
     Image link: https://freeimage.host/i/FXyGUxa
However, after a while the tool status will show up as following:
Image Link: https://freeimage.host/i/FXyVswX
8. Now, try to launch Synopsys Software
    8.a: VCS (Looks like it can run)
     8.b: Verdi (Cannot run)
Now, what I am doing wrong while doing above steps? Which step is missing or wrong? I will install DC later and will update that how it acts after installation.
Thanks.
P.S: I will release all files and user guide once I can run tool successfully.
 楼主| 发表于 2025-7-17 20:07:28 | 显示全部楼层
I could not attach all images. So, I attached some links.
发表于 2025-7-17 22:27:14 | 显示全部楼层
可以解决
发表于 2025-7-17 23:11:06 | 显示全部楼层
可以解决
 楼主| 发表于 2025-7-18 00:55:30 | 显示全部楼层
I have solved the problem. Before launching the tools, use SynopsysMonoSlayer to patch the tools. Link for monoslayer: https://bbs.eetop.cn/thread-978013-1-1.html
发表于 2025-7-18 04:56:38 | 显示全部楼层
good to know
GMT+8, 2025-12-20 19:41 , Processed in 0.026967 second(s), 4 queries , Gzip On, Redis On.
