查看: 1107|回复: 7
[资料] TCAS Ⅰ&Ⅱ 7月份合集
发表于 2025-7-3 14:02:36 | 显示全部楼层 |阅读模式
2025年7月份合集
IEEE Transactions on Circuits and Systems I: Regular Papers
IEEE Transactions on Circuits and Systems II: Express Briefs
(txt文件为百度网盘链接,请勿重复下载)
仅供学习交流,请勿商用
压缩包为整个期刊的pdf合集
或选取下方百度网盘链接
TCAS 1
Linearized Analysis and Quantization Error Minimization for Mid-Rise TDCs: A Tutorial ........... X. Wang and M. P. Kennedy 2986
Spurs in Fractional-N Frequency Synthesizers Resulting From Resolution Mismatch Between the Divider Controller and the DTC:
Manifestations, Analysis, and Mitigation ................................................................... X. Wang and M. P. Kennedy 2998
A Ka-Band Reconfigurable Dual-Band Variable Gain Amplifier With Low Phase Variation for 5G Communications ...............
........................................................................................... L. Gao, S. Zhang, X. Liu, J. Hu, and X. Y. Zhang 3012
A 48-dB Range, 0.86-dB Step, and 0.06-dB Error dB-Linear PGA Based on Resistive Ladder Attenuator: Design Theory and
Realization ...................................................... Y. Yin, H. Qi, Z. Feng, C. Jin, X. Zhang, H. Lu, L. Li, and R. Zhang 3024
An Ultra-Low Noise and Wide Output Range LDO With BJT Input Stage and Base Current Cancellation Technique ..............
......................................................................................... Y. Li, J. Jiang, P. Qu, Y. Zhao, F. Luo, and Z. Xiao 3038
A Capacitor-Coupled Offset-Canceled Sense Amplifier for DRAMs With Hidden Offset-Cancellation Time and Cross-Coupled
Pre-Sensing ........................................................................................................ I.-H. Jeon and J.-H. Chae 3048
A 362-TOPS/W Mixed-Signal MAC Macro With Sampling-Weight-Nonlinearity Cancellation and Dynamic-Amplified
Accumulation ............................................. R. Zhang, X. Cen, K.-F. Un, M. Guo, L. Qi, R. P. Martins, and S.-W. Sin 3059
Second-Order VCO-ADC Architecture With Low-Area and High Dynamic Range Using Internal Binary Encoding .................
............................................................. V. Medina, R. Garvi, J. Granizo, P. Amaral, and L. Hernandez Corporales 3072
An 11-bit 360-MS/s Pipelined SAR ADC With Feedback Factor Compensation Using a Dynamic Negative-C-Assisted Residue
Amplifier ...................................................................................................... Y. Kwon, J. Won, and Y. Chae 3084
A Highly Power- and Area-Efficient PMU for Cell-Size Autonomous Microsystems ......................................................
.................................................................. J. de Mena Pacheco, J. M. Carrillo, T. Palacios, and M. Lopez-Vallejo 3094
380-GHz Third Harmonic Signal Generation Using Differentially Pumped Varactors in a CMOS Voltage Controlled
Oscillator ............................................ Z. Chen, H. Dong, Z. Chen, W. Choi, J.-X. Chen, Kenneth K. O, and W. Hong 3104
Memristor-Based Selective Convolutional Circuit for High-Density Salt-and-Pepper Noise Removal ...................................
............................................................................................ B. Ding, L. Chen, C. Li, T. Huang, and S. Mitra 3115
Mixed-Signal Silicon Photomultiplier With Reconfigurable Pulse Shaper for Background Light Rejection ............................
............................................. A. Morciano, M. Gandola, M. Perenzoni, L. Gasparini, A. V. Radogna, and S. D’Amico 3126
A Study on Noise Folding Due to Nonlinearity in Fractional-N CP PLL ...................................................................
.......................................................................... S. Duan, Z. Li, X. Hu, Y. Wu, X. He, J. Leng, X. Cui, and L. Yu 3138
TCAS 2
1 Analog and Mixed Mode Circuits and Systems
A Peak-Injection CLS Technique for PVT-Robust Switched-Capacitor Amplifier . . . Y. Liang, P. Rui, R. Liu, R. Ding, and Z. Zhu 873
An 88.96 dB HDR CMOS Image Sensor Modeled on Visual Neuronal Response . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . J. Liu, Y. Wang, B. Xiong, Z. Li, L. Shi, and J. He 878
On-Chip Active Filter for Electrocardiographic Signals Through CMOS Pseudo Resistors . . . . . . . . . . . . . . . . V. R. Gonzalez-Diaz 883
2 Circuits and Systems for Communications
A 1.58 pJ/b 9 G bps Reference-Less Clock and Data Recovery Circuit With Sigma Range Detector . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . J. An, S.-M. Yu, G. An, S. Cheon, H. Jang, and J. Song 888
A Ku-Band Broadband 8-Channel 8-Beam Phased-Array Receiver With Polarization Agility and Beam Reconfiguration for
SATCOM Applications . . . . . . . . . . . . . . . . . . . . . . Z. Xie, Y. Feng, B. Huang, Z. Zhang, H. Zhao, L. Liu, Z. Liu, Z. Li, and X. Wu 893
3 Computer Aided Design and Electronic Design Automation
A Novel Error Metric for Evaluating the Error Correction Capability of Approximate Units . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Y. Dou, Z. Cai, H. Waris, R. Woods, and W. Liu 898
4 Control Theory and Systems
Reachable Set Estimation of Memristive Inertial Neural Networks . . . . . . . . . . . . . . . . . . . . . . . . Y. Jiang, S. Zhu, S. Wen, and C. Mu 903
OscNet: Machine Learning on CMOS Oscillator Networks . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . W. Cai, Z. Li, and T. H. Lee 908
Resilient Optimal Virtual Synchronous Generator Control Under DoS Attacks . . . . . . . . . . . . . . . B. Zhang, C. Deng, and B. Wang 913
5 Digital Circuits and Systems (and VLSI)
A Dual-Swing-Sample-and-Couple Sense Amplifier With Large Sensing Margin for STT-MRAM . . . . . . . . . . . . . . . . . . . . . . . . . . .
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Y. Wang, D. Song, J. Dai, E. Deng, Y. Gong, and W. Liu 918
TCAS1_2507.part1.rar
30 MB, 下载次数: 35 , 下载积分: 资产 -9 信元, 下载支出 9 信元
TCAS1_2507.part2.rar
30 MB, 下载次数: 34 , 下载积分: 资产 -9 信元, 下载支出 9 信元
TCAS1_2507.part3.rar
TCAS1_2507.part4.rar
30 MB, 下载次数: 39 , 下载积分: 资产 -9 信元, 下载支出 9 信元
TCAS1_2507.part5.rar
30 MB, 下载次数: 40 , 下载积分: 资产 -9 信元, 下载支出 9 信元
TCAS1_2507.part6.rar
17.93 MB, 下载次数: 38 , 下载积分: 资产 -6 信元, 下载支出 6 信元
TCAS2_2507.part1.rar
TCAS2_2507.part2.rar
8.98 MB, 下载次数: 35 , 下载积分: 资产 -4 信元, 下载支出 4 信元
TCAS2507.txt
166 Bytes, 下载次数: 31 , 下载积分: 资产 -2 信元, 下载支出 2 信元
售价: 25 信元资产  [记录]
百度网盘链接
发表于 2025-7-3 15:43:53 | 显示全部楼层
多谢分享
发表于 2025-7-3 18:49:58 | 显示全部楼层
多謝分享
发表于 2025-7-3 21:44:03 | 显示全部楼层
感谢分享!
发表于 2025-7-4 02:37:53 | 显示全部楼层
Thanks!!!!
发表于 2025-7-4 02:50:23 | 显示全部楼层
Thank you
发表于 2025-7-4 07:52:39 | 显示全部楼层
Thank you
发表于 2025-7-4 11:54:15 | 显示全部楼层
谢谢!
GMT+8, 2025-12-7 02:56 , Processed in 0.031197 second(s), 6 queries , Gzip On, Redis On.
