楼主: huanghua5211
rockylinux8.10自动读取cadence环境,就无法打开terminal
发表于 2025-6-26 03:20:39 | 显示全部楼层
thanks
发表于 2025-7-1 16:39:17 | 显示全部楼层
Newer export LD_LIBRARY_PATH in bashrc.
If this variable is set globally (or on a per-user basis), the system will search for libraries in locations specified by LD_LIBRARY_PATH first. This will slow down application loading times and can particularly affect GUI sessions.
LD_LIBRARY_PATH should only be set on a per-application basis like this:
$ LD_LIBRARY_PATH=/tool/bin some_dependent_program
You can also try to disable SELinux in your system
GMT+8, 2025-12-21 09:48 , Processed in 0.013447 second(s), 3 queries , Gzip On, Redis On.
