查看: 1566|回复: 11
rockylinux8.10自动读取cadence环境,就无法打开terminal
发表于 2025-6-23 16:58:12 | 显示全部楼层 |阅读模式
悬赏200资产已解决
# .bashrc
# Source global definitions
if [ -f /etc/bashrc ]; then
        . /etc/bashrc
fi
# Uncomment the following line if you don't like systemctl's auto-paging feature:
# export SYSTEMD_PAGER=
# User specific aliases and functions
########################cadence virtuoso studio#####################
export CADHOME=/edatools/cadence2024
export SPECTRE_DEFAULTS=-E
export LANG=C
export CDS_Netlisting_Mode=Analog
export CDS_ENABLE_VMS=1
export CDS_LOAD_ENV=CWD
export CDS=$CADHOME/IC231
export CDSDIR=$CDS
export CDSHOME=$CDS
export CADENCE_DIR=$CDS
export CDS_INST_DIR=$CDS
export CDS_ROOT=$CDS
export PATH=$CDSDIR/tools/binCDSDIR/tools/dfII/binPATH
export CDS_SPECTRERF_FBENABLE=1
export CDS_LIC_FILE=$CADHOME/license/license_studio.dat
export CDS_LIC_ONLY=1
export CDS_AUTO_64BIT=ALL
export OA_UNSUPPORTED_PLAT=linux_rhel50_gcc44x
export W3264_NO_HOST_CHECK=1
#####SPECTRE2410#####################
export SPECTRE_HOME=$CADHOME/SPECTRE241
export PATH=$SPECTRE_HOME/binSPECTRE_HOME/tools/bin:$PATH
export CDS_SPECTRE_FBENABLE=1
#########XCELIUMMAIN2024###################
export XCELIUMMAIN_HOME="/edatools/cadence2024/XCELIUMMAIN2409"
export PATH=$XCELIUMMAIN_HOME/bin:$XCELIUMMAIN_HOME/tools.lnx86/bin:$XCELIUMMAIN_HOME/tools.lnx86/dfII/bin:$PATH
export AMSSPICE_SPECTRE_DEBUG=YES
##############mentor2024###############
export MENTOR_HOME=/edatools/mentor2024
export CALIBRE_HOME=$MENTOR_HOME/calibre2024/aoj_cal_2024.1_28.16
export MGC_HOME=$CALIBRE_HOME
export MGLS_LICENSE_FILE=$MENTOR_HOME/license/license.dat
export PATH=$CALIBRE_HOME/bin:$PATH
export MGC_LIB_PATH=$CALIBRE_HOME/lib
export CALIBRE_ENABLE_SKILL_PEXBA_MODE=1
export MGC_CALIBRE_REALTIME_VIRTUOSO_ENABLED=1
export LD_LIBRARY_PATH=$CALIBRE_HOME/shared/pkgs/icv/tools/calibre_client/lib/64:$LD_LIBRARY_PATH
export MGC_CALIBRE_REALTIME_VIRTUOSO_SAVE_MESSENGER_CELL=1
export MGC_CALIBRE_SAVE_ALL_RUNSET_VALUES=1
export MGC_CALIBRE_LAYOUT_SERVER=127.0.0.1:1989
export MGC_CALIBRE_SCHEMATIC_SERVER=127.0.0.1:9199
export CALIBRE_ENABLE_CLASSIC_CI_DRC=1
export CALIBRE_ENABLE_CLASSIC_CI_LVS=1
export CALIBRE_ENABLE_CLASSIC_CI_PERC=1
export CALIBRE_ENABLE_CLASSIC_CI_PEX=1
export USE_CALIBRE_VCO=aoj
alias icfb='virtuoso &'
alias calib='calibre -gui'
#export CDS_LOG_PATH=/home/maxwell/virtuoso_workspace/
最佳答案
查看完整内容
我这边使用过程中没有发现异常
发表于 2025-6-23 16:58:13 | 显示全部楼层
crz4u 发表于 2025-6-24 17:24
export LANG=C改成export LANG=en_US.UTF-8或注释掉
我这边使用过程中没有发现异常
发表于 2025-6-24 09:02:56 | 显示全部楼层
有没有可能是LD_LIBRARY_PATH的问题
发表于 2025-6-24 13:38:30 | 显示全部楼层
export PATH=$PATHCALIBRE_HOME/bin
export LD_LIBRATY_PATH=$LD_LIBRARY_PATY.....
修改成这样试试,OS的PATH放前面。
发表于 2025-6-24 17:24:54 | 显示全部楼层
 楼主| 发表于 2025-6-24 20:20:40 | 显示全部楼层
取消这个影响大吗?
发表于 2025-6-25 00:25:44 | 显示全部楼层
1. check about package.
/edatools/cadence2024/IC231/tools/bin/checkSysConfig IC23.1
i've tested Rocky but IC23 doesn't match with the official supported OS list from cadence.
So you'd better change your /etc/rocky-release & /etc/os-release to RHEL 8.10 Version
2. there's a virtual machine file in this forum that already installed & able to execute IC Studio 23.
download and reference the .bashrc in the machine
发表于 2025-6-25 01:09:07 | 显示全部楼层
Thanks Kan Kan
发表于 2025-6-25 08:06:55 | 显示全部楼层
这个问题我在rhel 8中也遇到过,不知道root cause是什么。
我的解决方法是,将这些eda工具的环境变量写到另外一个环境变量文件中,比如/tools/eda.tcsh,然后再~/.bashrc中增加一行source /tools/eda.tcsh。
 楼主| 发表于 2025-6-25 08:57:11 | 显示全部楼层
我的解决方法是,将这些eda工具的环境变量写到 ...
一样的
GMT+8, 2025-9-29 03:19 , Processed in 0.016282 second(s), 5 queries , Gzip On, Redis On.
