查看: 756|回复: 1
[其它] HydroComp NavCad Premium 2023+PropCad 2023+propelement 2023+ PropExpert 2023
发表于 2025-6-9 21:11:25 | 显示全部楼层 |阅读模式
Hydrodynamic and Propulsion System Simulation
Quickly analyze vessel speed and power performance. NavCad provides maritime designers with the necessary tools for the optimized selection of suitable propulsion system components.
Unsurpassed in hydrodynamic design and analysis of ships
NavCad is the premier hydrodynamic and propulsion system simulation tool, providing powerful systems engineering calculations for the performance of marine vehicles. NavCad is built on a physics-based performance equilibrium of the Vessel-Propulsor-Drive system model, and is known for its reliable and confident prediction.
NavCad contains an extensive library of prediction methods for hulls, propulsors, and all necessary pieces, making it the most efficient and comprehensive platform for analysis from early-stage design through post-delivery trial evaluation. Used for any type of monohull or catamaran vehicle from large displacement vessels to fast planing craft to submersibles, it supports a variety of multiple drive options, including IC engines and electric motors.
Advanced Analyses
The advanced features in NavCad allow you to go beyond speed prediction. Quickly analyze a project for bollard towpull or determine time-to-speed using an acceleration analysis. Use a variety of multiple drive options, including IC engines and electric motors. Employ existing assets such as model tests, sea trials, or CFD calculations to correlate and align predictions – bringing you the highest fidelity with the least cost. Use supplemental analyses to check hydroacoustics, sinkage and trim, drag reduction, dynamic planing stability, and more.NavCad是用于预测和分析船速和船舶动力性能的专用软件的名称。该软件还非常适合选择合适的推进组件,例如发动机,变速箱和螺旋桨,并可以帮助您为所需的船只选择最佳的零件。您可以使用NavCad设计和分析任何类型的单体或高速船,并检查船只的类型。
NavCad软件是海军设计人员和工程师使用的专业且功能强大的软件。该程序能够分析舰壳之间的船舶性能,并评估各种多叶片风扇。该软件是用于模拟船速和功率性能的最完整平台,并具有广泛的阻力类型库。您可以将最终报告另存为PDF,DOC或CSV文件,请使用高精度分析软件。
PropCad 将您的图纸、报告和 3D 几何体保存在一个项目中。螺旋桨设计师和制造商使用 PropCad 来提高他们的生产力,在更短的时间内生产出更好的螺旋桨设计。PropCad 的界面提供对叶片参数和流体动力学截面形状的完全控制。它功能强大,速度快。标准设计和发行版库允许用户快速开发新设计和设计变体。功能丰富的工具可自动准备 2D 设计图纸、3D CAD 模型、施工数据和偏移报告,以及船级社厚度计算。用户可以设计、保存和导入自己的截面边栏选项卡定义。这些叶片部分可以通过添加外倾角或杯形来修改。设计人员可以创建具有渐进式螺距的高级叶片形状。PropCad 显示局部间距值,确保设计准确满足整体进度。使用 PropCad 全面的几何定义为任何船用螺旋桨准备无限设计。从 PropCad 的 Builder 库中输入螺旋桨样式、目标叶片面积比、倾斜量或倾斜量、厚度规则或许多其他设计目标。PropCad 构建整个几何体——弦长、厚度、倾斜、前倾和所有截面偏移。
螺旋桨制造设计
PropElements 在参数化规范和全 3D 设计之间提供了一个优化的设计阶段,用于制造。它建立在必要螺旋桨特性(例如NavCad的特性)的系统规范之上,以更详细地设计或评估螺旋桨,以满足船舶任务目标。许多大型商船使用定制螺旋桨,更多小型船舶、游艇和工作船也欣赏定制螺旋桨的好处。造船师现在面临着一系列新的技术挑战,以确保可接受的性能并符合设计要求。为了充分利用定制或半定制螺旋桨提供的好处——或在服务中评估它们——造船工程师必须考虑不同类型的螺旋桨计算。对 PropElements 的广泛验证研究证实,它在计算保真度和工作流程效率方面无与伦比。HydroComp 的 PropElements 为更广泛的工程社区带来了专业工具。PropElements不仅为螺旋桨专家和制造商设计,还为造船工程师和车辆设计师设计。
PropExpert提供最新的技术,在一个易于使用和强大的软件包中呈现。计算开放式或涵道式螺旋桨系统的最佳直径、螺距、减速齿轮比和叶片面积。PropExpert是选择和分析工作船和游艇螺旋桨系统的理想选择。只需几个输入,即可自信地识别特定于船舶的推进系统组件。已安装的商业螺旋桨库可以使用您自己的数据进行扩展,并构建您自己的船舶、发动机和变速箱库。利用先前试验或类似船只的数据将您的模型锚定到真实世界的性能,或者在没有数据的情况下使用 PropExpert 的速度估计公式。PropExpert 的项目库可以帮助您管理项目、船舶、螺旋桨、发动机和减速齿轮模型的数据库。使用软件的两级“确定尺寸然后分析”解决方案实现最佳性能,以确定最高速度、推力、功率和效率。
NavCad软件的功能:
预测船体阻力
  • 静态漂移模式分析
  • 选择合适的推进系统组件,包括发动机,变速箱和螺旋桨
  • 计算船速
  • 各类船的设计与分析
  • 支持PDF,DOC或CSV输出格式
HydroComp NavCad Premium 2023+PropCad 2023+propelement 2023+ PropExpert 2023都有,需要联系3766906032@qq.com
发表于 2025-8-25 14:03:01 | 显示全部楼层
下载
GMT+8, 2025-9-14 10:08 , Processed in 0.013136 second(s), 5 queries , Gzip On, Redis On.
