查看: 1241|回复: 3
[求助] virtuoso仿真报错
发表于 2025-6-4 20:43:26 | 显示全部楼层 |阅读模式
Fatal error found by spectre during topology check.
    FATAL: The following branches form a loop of rigid branches (shorts) when added to the circuit:
        L10:1 (from net9 to VDD)
求助
发表于 2025-6-4 21:31:00 来自手机 | 显示全部楼层
盲猜电感和一个电压源短路了
 楼主| 发表于 2025-6-4 22:02:38 | 显示全部楼层
ckseu 发表于 2025-6-4 21:31
盲猜电感和一个电压源短路了
L10并联就会报错,仿真时间长了发现这个也会报错
        V0:p (from VDC1 to 0)
不理解
发表于 2025-6-5 17:05:53 | 显示全部楼层
答案都写出来了,V0器件的P端VDC1这根线对地短路了
GMT+8, 2025-12-18 00:39 , Processed in 0.014771 second(s), 3 queries , Gzip On, Redis On.
