查看: 824|回复: 4
t28 memory使用求助
发表于 2025-4-13 10:25:14 | 显示全部楼层 |阅读模式
求助t28 sram文档中这两个note是什么意思,我在配置为272x4M4F出错。咨询一下具体可以配置的范围。
发表于 2025-4-13 10:56:53 | 显示全部楼层
Note 1 is applicable to your configuration and is not supported
You have depth W=272 and mux CM=4 => WL=W/CM=68 which is not supported.
 楼主| 发表于 2025-4-13 11:58:14 | 显示全部楼层
You have depth W=272 and mux CM=4  ...
thank you, I will check it by your description
 楼主| 发表于 2025-4-13 20:23:35 | 显示全部楼层
you are right, I have test all the configure, and the result proves that you are completely right
发表于 2025-4-13 21:03:42 | 显示全部楼层
sure, you are welcome
GMT+8, 2025-12-21 05:42 , Processed in 0.016450 second(s), 5 queries , Gzip On, Redis On.
