查看: 1125|回复: 5
[原创] Open-source tool to optimize analog circuits
发表于 2025-4-1 16:13:11 | 显示全部楼层 |阅读模式
I wrote a tool called Mosplot that does three main things:
1. Generate lookup tables of all interesting MOSFET parameters, capturing all the characteristics of a transistor.
2. Using the lookup table, all sorts of fancy plots of MOSFET parameters can be made easy extremely easily without having to simulate the circuit every time.
3. Using the lookup table, analog circuits with design specifications can be easily optimized, as long as you can write the equations that define how the specifications are computed. For instance, you can optimize a 5T-OTA for a given specification in a given technology in just a few seconds.
https://github.com/medwatt/gmid
It is written in python. You can see many examples of how to make plots and also one example of how one can write a script to optimize a 5T-OTA.
I initially wrote this tool because I was looking for an open-source tool that generates plots for the gm/ID methodology. However, as I was growing tired of having to constantly redesign circuits with different specifications, I realized that having the lookup table and the power of optimization methods, I can easily automate the whole process. At the moment, there's only a single script for the 5T-OTA, but I plan to add more in the future. In this way, we could have a repository of designs that could be trivially optimized for any technology. Of course, the tool is completely open-source and I welcome any contributions or suggestions that improve the tool.
发表于 2025-4-2 15:55:30 | 显示全部楼层
good job. Thanks.
发表于 2025-4-3 16:15:06 | 显示全部楼层
发表于 2025-4-3 20:26:30 | 显示全部楼层
太好了,就是我打不开github
发表于 2025-4-5 14:44:39 来自手机 | 显示全部楼层
mastermicro ADT跟你干的一样的
发表于 2025-4-5 16:20:54 | 显示全部楼层
楼主辛苦了
GMT+8, 2025-12-28 23:26 , Processed in 0.021819 second(s), 3 queries , Gzip On, Redis On.
