查看: 769|回复: 1
[求助] CSMC BCD工艺的DRC报错A1_Space_60V80V
发表于 2025-4-1 11:50:48 | 显示全部楼层 |阅读模式
这里报了这个错,但是点过去却什么都没发现。
A1_Space_60V80V {
        @A1_Space: Minimum space of A1 between (60v80v) and (lv/10v12v15v_35v_60v80v) at different potentialscheck this rule inside the region which A1 connected to TO or GT interacting with HV_80V or HV_60V or HV_L80)-----0.6
        X  = EXTERNAL m1_hv_60v80v m1_lv <0.6 REGION SINGULAR ABUT<90
        X1 = EXTERNAL m1_hv_60v80v m1_hv_10v12v15v <0.6 REGION SINGULAR ABUT<90
        X2 = EXTERNAL m1_hv_60v80v m1_hv_35v <0.6 REGION SINGULAR ABUT<90
        X3 = EXTERNAL m1_hv_60v80v <0.6 REGION SINGULAR ABUT<90
        X4 = EXTERNAL m1_hv_drain_diff_60_80 <0.6 REGION SINGULAR ABUT<90
        X5 = EXTERNAL m1_hv_drain_diff_60_80 m1_all_no_drain <0.6 REGION SINGULAR ABUT<90
        Y  = EXTERNAL a1_conn<0.6 REGION NOT CONNECTED SINGULAR ABUT<90
        NOT INSIDE ( X  INTERACT Y ) EXCL
        NOT INSIDE ( X1 INTERACT Y ) EXCL
        NOT INSIDE ( X2 INTERACT Y ) EXCL
        NOT INSIDE ((X3 INTERACT Y ) NOT HV_60v80v) EXCL
        NOT INSIDE ( X4 INTERACT Y ) EXCL
        NOT INSIDE ( X5 INTERACT Y ) EXCL
发表于 2025-4-1 13:28:29 | 显示全部楼层
把做DRC的GDS文件(.calibre.db文件)Stream In到一个新库看看。
GMT+8, 2025-10-22 06:37 , Processed in 0.030806 second(s), 4 queries , Gzip On, Redis On.
