楼主: happyfeng
cadence ic610 在SUSE10.1安装步骤及LIxxxxx
发表于 2009-12-22 18:01:55 | 显示全部楼层
发表于 2009-12-29 02:21:04 | 显示全部楼层
thanks
发表于 2009-12-29 09:42:13 | 显示全部楼层
Thanka a lot!
发表于 2010-1-1 10:21:54 | 显示全部楼层
谢谢了,楼主
发表于 2010-1-6 16:44:26 | 显示全部楼层
thanks
发表于 2010-1-6 19:48:25 | 显示全部楼层
thanks for sharing
发表于 2010-1-21 00:09:27 | 显示全部楼层
8# happyfeng
cadence.cshrc - Berkeley Sensor & Actuator CenterFeb 20, 2009 ... endif if !(-e ~/.cdsinit)  ln -s ~cadence/config/cadenc
发表于 2010-1-21 00:10:42 | 显示全部楼层
10# test3 recently installed RHEL 5 with the intent to install IC610. However,
lo and behold, I found out that IC610 is recommended for RHEL4 or
RHEL3 for a x86-32bit machine. (I had hoped that RHEL5 will be
backwards compatible).
RHEL5 usually is backward compatible, unless Cadence did somethingugly. Have you tried (I haven't - all the people here still use5.1.41)? Cadence seems to be very conservative with Linux OSes, I havehad this problem several times. I install the newest Linux, since wefrequently update the hardware of our CAD workstations (get faster newmachines), and old Linux distributions just don't work on newmainboards (RHEL3 is what? 2003? No sane person should work on aworkstation from 2003 today!). Sometimes you just need a shared libraryfrom one of the old distributions.
发表于 2010-1-21 02:16:46 | 显示全部楼层
30# ghung kankan
发表于 2010-1-21 02:25:54 | 显示全部楼层
210# cweiln kankan
GMT+8, 2025-12-24 09:02 , Processed in 0.019611 second(s), 4 queries , Gzip On, Redis On.
