查看: 843|回复: 0
[求助] 关于仿真中model的几个问题
发表于 2025-3-28 13:29:05 | 显示全部楼层 |阅读模式
仿真时提示几个warning,请教下是什么意思
1. `par1_1n' redefines parameter of same name defined at higher level. Local parameter value will be used.
2.Scope option `scale' specified with scope `TopCircuit' at line `35' has also been specified at line .....As a result, the last specified value will be used for simulation.
3.The option 'gmin' is deleted because it is redefined at 'input.scs':line '1854'.
关于第一个问题,我理解的是底层mdl的model中这个参数已经在更上层的文件定义了,属于PDK中model定义问题,应该不影响仿真结果?
关于第二三个问题,scale和gmin,gmindc在model已经定义过了,如果ADE中再有定义的话,会以ADE中为准吗?
GMT+8, 2025-12-28 22:27 , Processed in 0.010928 second(s), 3 queries , Gzip On, Redis On.
