查看: 933|回复: 2
[求助] UPF中powe state的设置
发表于 2025-3-27 11:45:10 | 显示全部楼层 |阅读模式
set_scope I_STACK_TOP/I_STACK_FSM
add_power_state -supply SS_FSM -state {ON -supply_sxpr {power == {FULL_ON 0.8} && groud == {FULL_ON 0}}}
set_scope /
create_power_state_group my_pst
add_power_state -group my_pst -state {RUN -logic_expr {SS_FSM == ON}}
PT 报ERROR :the named object 'SS_FSM' in logic_expr for state 'RUN' can not be found.(UPF-715)
把SS_FSM改为I_STACK_TOP/I_STACK_FSM/SS_FSM还是报同样的错误, 有哪位大大知道这种在顶层power state设下面子模块的power 状态的要怎么写吗?
发表于 2025-4-2 13:29:49 | 显示全部楼层
power state  里面的supply set SS_FSM 你没定义
 楼主| 发表于 2025-4-3 11:55:52 | 显示全部楼层
SS_FSM这个supply set我定义在sub module I_STACK_TOP/I_STACK_FSM里了,PT 2019能识别我在submodule里add_power_state 给supply set设的power state, 但PT 2022不能识别,后面把supply_set都改到top模块后这个power state group终于设置成功了
GMT+8, 2025-12-20 11:48 , Processed in 0.015735 second(s), 3 queries , Gzip On, Redis On.
