查看: 2712|回复: 11
[资料] 一些经典产品的版图分享
发表于 2025-3-17 16:33:07 | 显示全部楼层 |阅读模式
跟大家一起欣赏“模拟版图的艺术”,资料来源网络,仅供学习~~
今日分享:TI 产品SN74AHC1G00 ,单通道双输入正与非门,实现 功能: Y = A• B 或 Y = A + B。该产品最早的数据手册可追溯到1996年,且至今仍在售。
The simplest possible microchip, SN74AHC1G00,  made by Texas Instruments. Die size 520x420 µm.
After etching 2(!) metal layers, we can see that chip area occupied mostly by pads, input protection, and output transistors. Funny rainbow things below pads - partially etched insulating dielectric masked by what's left from gold bond wires.
 楼主| 发表于 2025-3-18 13:46:39 | 显示全部楼层
今日分享: PI产品 TNY264-- TinySwitch-II Family 之一, 可以看到芯片内部集成了 700 V power MOSFET。
Die size 2457x1306 µm.
 楼主| 发表于 2025-3-25 12:01:07 | 显示全部楼层
三款经典的logic shift register, 分别来自NXP, fairchild, OnSemic.
NXP 74HC595 - yet another standard logic shift register.
Die size 953x866 µm, 2µm manufacturing technology.
Fairchild 74VHC595 - standard logic chip, 8-bit shift register.
Die size 800x690 µm. 800nm manufacturing technology.
ON Semiconductor 74HC595 is a 8-bit shift register (serial-in parallel-out).
That's incredible: 47 years passed since 7400 TTL logic introduction - it is still manufactured and used in new products.
 楼主| 发表于 2025-4-1 15:39:59 | 显示全部楼层
今日分享:
UTC LM2940L-5.0 - 1A low-dropout linear regulator.
Apparently 5 contacts at the bottom-right were used to fine-tune output voltage by burning fuses between them.
发表于 2025-4-1 16:07:53 | 显示全部楼层
多来点多来点,最喜欢欣赏这种照片了
 楼主| 发表于 2025-4-2 10:37:40 | 显示全部楼层
lingchention 发表于 2025-4-1 16:07
多来点多来点,最喜欢欣赏这种照片了
感谢回复。
 楼主| 发表于 2025-4-6 13:41:42 | 显示全部楼层
Playstation 1 CPU - CXD8530CQ based on 33.8688 MHz MIPS R3051 core manufactured at 800nm technology, 3 layers of metalization.
 楼主| 发表于 2025-4-15 15:27:44 | 显示全部楼层
STMicroelectronics 34C02 is an 2048-bit EEPROM with hardwire write-protect and I2C interface, typically used as SPD chip in DIMM memory modules.
Die size 1542x1422 µm, 1.2µm half-pitch。
发表于 2025-4-18 18:05:39 | 显示全部楼层
好111
发表于 2025-4-20 13:16:17 | 显示全部楼层
thanks
GMT+8, 2025-10-26 07:53 , Processed in 0.021069 second(s), 4 queries , Gzip On, Redis On.
