查看: 655|回复: 0
[原创] clock downstream
发表于 2025-2-19 19:36:35 | 显示全部楼层 |阅读模式
时钟门控检查对于门控信号的要求是
the clock gating check applies to the gating signal. The signal at the gating pin of the check should not be a clock or if it is a clock, it should not be used as a clock downstream.
但是如图这种情况为什么CLKB不是一个clock downstream?
GMT+8, 2025-11-9 18:35 , Processed in 0.031515 second(s), 4 queries , Gzip On, Redis On.
