楼主: chiphell
启动2024.09版S报错FLEXlm版本高于license daemon版本
发表于 2025-2-19 15:17:05 | 显示全部楼层
why?
发表于 2025-2-19 19:13:33 | 显示全部楼层
cotonier 发表于 2025-2-19 08:26
我也想知道哪里看FLEXlm version,这个FLEXlm version是由谁决定的,有时候也遇到FLEXlm version比启动lice ...
The SCL version is one thing, the FlexLM version is another thing.
The majority of newer releases are working with verion FlexLM 11.19.xx
Regarding the SCL (https://www.synopsys.com/support ... orms/licensing.html)
  1. Determining Your Current SCL Version
  2. To determine your SCL version, do the following:
  3. % cd scl_root/<platform>/bin
  4. % ./whatscl snpslmd
  5. ==> Synopsys Corporate Licensing (SCL) Release: version SCL 2024.06 ...
  6. Alternately, on Linux (only), you may determine your SCL version via the Linux strings command:
  7. % strings /path/to/snpslmd | grep Release
  8. Note that these results give the Synopsys version, not the FlexNet version. The FlexNet version for SCL <b>SCL 2023.09 is 11.19.4.1</b> and for <b>SCL 2024.06 is 11.19.6</b> (lmgrd, snpslmd, lmstat, etc.).
    复制代码
Regarding the problem , may be there the daemon is running from a different location without being noticed?
发表于 2025-2-28 19:36:23 | 显示全部楼层
很明显你的 lic file 里面那行叫 license 起来的 daemon,用的太旧了。
发表于 2025-2-28 19:37:33 | 显示全部楼层
很明显你的 lic file 里面那行 daemon 路径用到的版本太旧了。
发表于 2025-3-4 10:48:15 | 显示全部楼层
目前看起來沒有解法
发表于 2025-6-10 18:45:52 来自手机 | 显示全部楼层
krman33 发表于 2025-2-19 09:21
可以分享吗?
GMT+8, 2025-12-29 02:19 , Processed in 0.015292 second(s), 3 queries , Gzip On, Redis On.
