查看: 2979|回复: 7
synopsy scl2024.06启动license报错
发表于 2025-2-14 00:00:08 | 显示全部楼层 |阅读模式
23:58:38 (lmgrd) Server's System Date and Time: Thu Feb 13 2025 23:58:38 CST
23:58:38 (lmgrd) Changing message security level from -1 to 0
23:58:38 (lmgrd) SLOG: Summary LOG statistics is enabled.
23:58:38 (lmgrd) FlexNet Licensing (v11.19.6.0 build 293152 x64_linux) started on s11b01n02 (linux) (2/13/2025)
23:58:38 (lmgrd) Copyright (c) 1988-2024 Flexera. All Rights Reserved.
23:58:38 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
23:58:38 (lmgrd) License file(s): /appsnew/sentaurus_tcad/license/Synopsys.dat
23:58:38 (lmgrd) lmgrd tcp-port 27000
23:58:38 (lmgrd) (@lmgrd-SLOG@) ===============================================
23:58:38 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
23:58:38 (lmgrd) (@lmgrd-SLOG@) Start-Date: Thu Feb 13 2025 23:58:38 CST
23:58:38 (lmgrd) (@lmgrd-SLOG@) PID: 93627
23:58:38 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.19.6.0 build 293152 x64_linux ( build 293152 (ipv6))
23:58:38 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
23:58:38 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
23:58:38 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
23:58:38 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
23:58:38 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /appsnew/sentaurus_tcad/license/Synopsys.dat -l /appsnew/sentaurus_tcad/license/lic.log
23:58:38 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /appsnew/sentaurus_tcad/license/Synopsys.dat
23:58:38 (lmgrd) Starting vendor daemons ...
23:58:38 (lmgrd) Started snpslmd (internet tcp_port 35267 pid 93635)
23:58:44 (snpslmd) FlexNet Licensing version v11.19.6.0 build 293152 x64_linux
23:58:45 (snpslmd) Cannot open daemon lock file
23:58:45 (snpslmd) EXITING DUE TO SIGNAL 41 Exit reason 9
23:58:45 (lmgrd) snpslmd exited with status 41 (Exited because another server was running)
23:58:45 (lmgrd) MULTIPLE "snpslmd" license server systems running.
23:58:45 (lmgrd) Please kill, and run lmreread
23:58:45 (lmgrd)
23:58:45 (lmgrd) This error probably results from either:
23:58:45 (lmgrd)   1. Another copy of the license server manager (lmgrd) is running.
23:58:45 (lmgrd)   2. A prior license server manager (lmgrd) was killed with "kill -9"
23:58:45 (lmgrd)       (which would leave the vendor daemon running).
23:58:45 (lmgrd) To correct this, do a "ps -ax | grep snpslmd"
23:58:45 (lmgrd)   (or equivalent "ps" command)
23:58:45 (lmgrd) and kill the "snpslmd" process.
23:58:45 (lmgrd)
[liujz@s11b01n02 license]$
发表于 2025-2-14 08:40:18 | 显示全部楼层
1. 用lmdown -c 后面加你的License文件名关闭一下service
2. 杀掉所有snpslmd进程
3. 等一段时间在lmgrd -c试试
发表于 2025-2-14 15:34:00 | 显示全部楼层
发表于 2025-2-14 16:10:10 | 显示全部楼层
23:58:45 (lmgrd) MULTIPLE "snpslmd" license server systems running. 23:58:45 (lmgrd) Please kill, and run lmreread
发表于 2025-2-15 03:20:55 | 显示全部楼层
good catch
发表于 2025-5-8 17:55:16 | 显示全部楼层
最后咋解决的,我也遇到了,没有多个进程,开始用root不行,普通用户也有这个问题,后来又突然好了
发表于 2025-5-11 14:47:10 | 显示全部楼层
wsid 发表于 2025-5-8 17:55
最后咋解决的,我也遇到了,没有多个进程,开始用root不行,普通用户也有这个问题,后来又突然好了 ...
https://zhuanlan.zhihu.com/p/433125915
发表于 2025-5-12 07:54:16 | 显示全部楼层
我去看看,谢谢大佬
GMT+8, 2025-12-21 19:13 , Processed in 0.017774 second(s), 4 queries , Gzip On, Redis On.
