查看: 6228|回复: 56
[原创] ISPD 2024
发表于 2025-1-18 12:10:54 | 显示全部楼层 |阅读模式
ISPD 2024 下载到的论文,Summary到一起了,Title如下:
2_1_slides_final[MedPart A Multi-Level Evolutionary Differentiable Hypergraph Partitioner].pdf
2_2_slides_final[FuILT Full Chip ILT System With Boundary Healing].pdf
2_3_slides_final[Slack Redistributed Register Clustering with Mixed-Driving Strength Multi-bit Flip-Flops].pdf
3_1_slides_final[Calibration-Based Differentiable Timing Optimization in Non-linear Global Placement].pdf
3_2_slides_final[Novel Airgap Insertion and Layer Reassignment for Timing Optimization Guided by Slack Dependency].pdf
3_3_slides_final[Parallel and Heterogeneous Timing Analysis Partition, Algorithm, and System].pdf
4_1_slides_final[EDA Needs at Advanced Technology Nodes].pdf
4_2_slides_final[EDA Challenges at Advanced Technology Nodes].pdf
4_3_slides_final[Challenges in Floorplanning and Macro Placement for Modern SoCs].pdf
5_1_slides_final[Routing-aware Legal Hybrid Bonding Terminal Assignment for 3D Face-to-Face Stacked ICs].pdf
5_2_slides_final[Unified 3D-IC Multi-Chiplet System Design Solution].pdf
5_3_slides_final[Warpage Study by Employing an Advanced Simulation Methodology for Assessing Chip Package Interaction Effects].pdf
5_4_slides_final[Enabling System Design in 3D Integration Technologies and Methodologies].pdf
6_1_slides_final[FastTuner Transferable Physical Design Parameter Optimization using Fast Reinforcement Learning].pdf
6_2_slides_final[Methodology of Resolving Design Rule Checking Violations Coupled with Fully Compatible Prediction Model].pdf
6_3_slides_final[AI for EDAPhysical Design].pdf
6_4_slides_final[DSO.ai – A distributed system to optimize design flows].pdf
6_5_slides_final[Solvers, Engines, Tools and Flows The Next Wave for AIML in Physical Design].pdf
7_1_slides_final[Physical Design Challenges in Modern Heterogeneous Integratio].pdf
8_1_slides_final[Fundamental Differences Between Analog and Digital Design Problems].pdf
8_2_slides_final[Layout Verification Using Open-Source Software].pdf
8_3_slides_final[Reinforcement Learning or Simulated Annealing for Analog Placement A Study based on Bounded-Sliceline Grids].pdf                                                  9_1_slides_final[Practical Mixed-Cell-Height Legalization Considering Vertical Cell Abutment Constraint].pdf
9_2_slides_final[Multi-Electrostatics Based Placement for Non-Integer Multiple-Height Cells].pdf
9_3_slides_final[IncreMacro Incremental Macro Placement Refinement].pdf
9_4_slides_final[Timing-Driven Analytical Placement According to Expected Cell Distribution Range].pdf
10_1_slides_final[Routability Booster–Synthesize a Routing Friendly Standard Cell Library by Relaxing BEOL Resources].pdf
10_2_slides_final[Novel Transformer Model Based Clustering Method for Standard Cell Design Automation].pdf
10_3_slides_final[Power Sub-Mesh Construction in Multiple Power Domain Design with IR Drop and Routability Optimization].pdf                                                               11_1_slides_final[Introduction of 3D IC Thermal Analysis Flow].pdf
11_2_slides_final[3Dblox Unleashing The Ultimate 3DIC Design Productivity].pdf
11_3_slides_final[Challenges for Automating PCB Layout].pdf
12_1_slides_final[Scheduling and Physical Design].pdf
12_2_slides_final[Accelerating EDA from 1 to N].pdf
12_3_slides_final[Pioneering Contributions of Professor Martin D. F. Wong].pdf
12_4_slides_final[My Journey in EDA].pdf
13_1_slides_final[Computing Architecture for Large Language Models (LLMs) and Large Multimodal Models (LMMs)].pdf
14_1_slides_final[SMT-Based Layout Synthesis].pdf
14_2_slides_final[Qubit Mapping for Trapped-Ion Systems Using].pdf
14_3_slides_final[Optimization for Buffer and Splitter Insertion in].pdf
15_1_slides_final[Design Automation Challenges for Automotive Systems].pdf
15_3_slides_final[Solving the Physical Challenges for the Next Generation of].pdf
16_1_slides_final[ISPD'24 Contest GPUML-Enhanced Large Scale Global Routing Contest].pdf
16_2_slides_final[Closing Remarks].pdf
ISPD-2024.zip.005.zip (28.4 MB , 下载次数: 37 )
ISPD-2024.zip.004.zip (32 MB , 下载次数: 38 )
ISPD-2024.zip.003.zip (32 MB , 下载次数: 39 )
ISPD-2024.zip.002.zip (32 MB , 下载次数: 42 )
ISPD-2024.zip.001.zip (32 MB , 下载次数: 41 )
附件下载之后,会带一个.zip的后缀(*.zip.001.zip,因为网站要求后缀),解压的时候将最后一个.zip去掉,如上图。
解压密码,回复后可见。
游客 ,如果您要查看本帖隐藏内容请回复
 楼主| 发表于 2025-1-18 13:45:53 | 显示全部楼层
自己去网站上查好像也行。
发表于 2025-1-18 16:59:23 | 显示全部楼层
nice share
发表于 2025-1-18 17:17:52 来自手机 | 显示全部楼层
可以看看的
发表于 2025-1-18 17:58:30 | 显示全部楼层
thanks
发表于 2025-1-18 18:35:51 | 显示全部楼层
谢谢分享!
发表于 2025-1-18 18:49:48 | 显示全部楼层
kankan.thx
 楼主| 发表于 2025-1-18 19:37:10 | 显示全部楼层
能看到附件嘛,我怎么找不到附件,我上传了哇。。
发表于 2025-1-18 21:41:35 | 显示全部楼层
下载学习下
发表于 2025-1-19 02:06:50 | 显示全部楼层
看看不错的帖子
GMT+8, 2025-10-17 08:19 , Processed in 0.026978 second(s), 5 queries , Gzip On, Redis On.
