查看: 1361|回复: 5
TCAD跑tcadtospice出现的错误,大家有经验吗?
发表于 2025-1-9 14:11:18 | 显示全部楼层 |阅读模式
悬赏1000资产已解决
/remote/swefs1/PE/products/tcad/w2024.09_dev/clientstore/tcad_w2024.09_dev_build1/enigma/lib/python3.11/site-packages/enigma/enigma3.py:520: UserWarning: Couldn't find a compatible queueing system in the environment. Please ensure a queueing system is loaded before running Enigma
Traceback (most recent call last):
  File "<string>", line 11, in <module>
  File "/remote/swefs1/PE/products/tcad/w2024.09_dev/clientstore/tcad_w2024.09_dev_build1/enigma/lib/python3.11/site-packages/enigma/enigma3.py", line 587, in run_script
enigma.core.exc.ProjectError: Could not find the database configuration file /usr/synopsys/sentaurus/W-2024.09/tcad/W-2024.09/Applications_Library/GettingStarted/tcadtospice/setup/DB_tutorial/enigma/mongodb.conf, please check your user in configured correctly
ERROR on evaluation of Python script
最佳答案
查看完整内容
后台告诉你吧
发表于 2025-1-9 14:11:19 | 显示全部楼层
后台告诉你吧
发表于 2025-2-17 13:35:47 | 显示全部楼层
我也想知道,我也遇到这个问题,是python配置的问题吗?
发表于 2025-4-8 00:42:06 | 显示全部楼层
你是ubuntu系统吗?
发表于 2025-4-8 02:13:45 | 显示全部楼层
Thanks for nothing so far
发表于 2025-7-26 18:02:11 | 显示全部楼层
请问这是什么原因呢?我这边也有这个问题
GMT+8, 2025-12-14 00:16 , Processed in 0.017442 second(s), 5 queries , Gzip On, Redis On.
