查看: 7036|回复: 24
$yn0p$ys syn W-2024.09-SP1 patch求助
发表于 2024-12-20 17:30:37 | 显示全部楼层 |阅读模式
用scl_keygen.exe弄的license,Crack syn  W-2024.09-SP1 。
Synopsys.src 文件1185KB那个大小的。
用SynopsysMonoSlayer -a 了一遍后,启动lmgrd -c license.dat 。如下提示, 不知道是SCL 没有crack OK。还是license feature 有问题。
22:58:35 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  doradod  EPIC  eved  extremed  fishtail  hscd  imperasd  innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  piketec  riod  saber_dmn  sandwork  sclmgrd  sftlmd  sigmacd  SIINT  simple  snpsOEM1  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd  wlld
12/22/2024 22:58:39 (snpslmd) ------------------------------------------------------------------
12/22/2024 22:58:39 (snpslmd) Checking the integrity of the license file...
12/22/2024 22:58:39 (snpslmd) Valid SSS feature found.
12/22/2024 22:58:39 (snpslmd) The feature is needed to enable the other keys in your license file.
12/22/2024 22:58:39 (snpslmd) Licensed to student@eetop
12/22/2024 22:58:39 (snpslmd) Siteid: 26356, Server Hostid: FEFCFEBB16EB, Issued on: 1/8/2014
12/22/2024 22:58:39 (snpslmd) You are attempting to run the license server on a non-privileged domain/zone
12/22/2024 22:58:39 (snpslmd) Synopsys Licensing Server is restricted to run in this zone. Please contact support_center@synopsys.com for help
22:58:39 (lmgrd) snpslmd exited with status 33 (Bad configuration data)
22:58:39 (lmgrd) Please correct problem and restart daemons
发表于 2024-12-21 00:03:27 | 显示全部楼层
 楼主| 发表于 2024-12-21 09:16:28 | 显示全部楼层
难受至极 发表于 2024-12-21 00:03
https://bbs.eetop.cn/thread-978013-1-1.html 可以试试看这个
谢谢,那license生成用哪个呢
发表于 2024-12-21 10:51:08 | 显示全部楼层
thanks
发表于 2024-12-21 18:15:02 | 显示全部楼层
where it  ?   syn W-2024.09-SP1
发表于 2024-12-21 20:55:57 | 显示全部楼层
starkwork 发表于 2024-12-21 09:16
谢谢,那license生成用哪个呢
不用了啊,只要缺什么feature补什么就好了
 楼主| 发表于 2024-12-22 21:24:18 | 显示全部楼层
license报错
发表于 2024-12-23 13:38:38 | 显示全部楼层
你的lic看上去没问题,换个普通用户去起lmgrd试试吧
 楼主| 发表于 2024-12-23 13:43:32 | 显示全部楼层
是普通用户登上去的。不是root
 楼主| 发表于 2024-12-23 14:18:21 | 显示全部楼层
starkwork 发表于 2024-12-23 13:43
是普通用户登上去的。不是root
[tcad@SYN ~]$ icc2_shell
[SCL] Error:  One possible reason for this error is that FLEXlm version of the application is higher than the license daemon version. If this is the case, please upgrade the license daemon to latest version (SCL-602)
Unable to get shell start-up license keys. Cannot invoke shell. Following license(s) must exist : {ICCompilerII or ICCompilerII-NX}.
Maximum memory usage for this session: 105.59 MB
Maximum memory usage for this session including child processes: 105.59 MB
CPU usage for this session:      7 seconds (  0.00 hours)
Elapsed time for this session:      7 seconds (  0.00 hours)
Thank you for using IC Compiler II.
[tcad@syn ~]$ dc_shell
/usr/synopsys/syn/W-2024.09-SP1/bin/dc_shell: /usr/synopsys/syn/W-2024.09-SP1/bin/snps_platform: /bin/csh: bad interpreter: No such file or directory
Info: [VCS_SAVE_RESTORE_INFO] ASLR (Address Space Layout Randomization) is detected on the machine. To enable $save functionality, ASLR will be switched off and simv re-executed.
Please use '-no_save' simv switch to avoid this.
Fatal: Design Compiler is not enabled. (DCSH-1)
站长推荐 上一条 /3 下一条
GMT+8, 2025-9-10 06:30 , Processed in 0.018006 second(s), 5 queries , Gzip On, Redis On.
