查看: 760|回复: 1
[求助] cadence仿真tsmc coms 0.18um 的MOS管报错,Unable to make index for library file
发表于 2024-12-17 17:30:42 | 显示全部楼层 |阅读模式
** Creating circuit file "double-ended test1.cir"
** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS
*Libraries:
* Profile Libraries :
* Local Libraries :
* From [PSPICE NETLIST] section of D:\cadence\Cadence\SPB_Data\cdssetup\OrCAD_PSpice/16.6.0/PSpice.ini file:
.lib "D:\fangzhen\tsmc\tsmc018r.lib"
.lib "D:\cadence\Cadence\SPB_16.6\tools\pspice\library\nom.lib"
.lib "D:\fangzhen\snspd-spice-master\snspd.lib"
*Analysis directives:
.TRAN  0 1000ns 0 10p
.OPTIONS ADVCONV
.PROBE64 V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source DOUBLE-ENDED READOUT
V_V3         N05580 0
+PULSE 0 1u 0 10p 10p 100p 1000
V_V1         N06115 0 1m
M_M1         N06208 N06212 0 0 NCH6
M_M2         N06204 N06212 0 0 NCH6
M_M3         1.8 N06115 N05400 N05400 PCH6
M_M4         1.8 N06115 N06115 N06115 PCH6
M_M5         N05400 0 N06208 N06208 PCH6
M_M6         N05400 N06237 N06204 N06204 PCH6
R_R1         0 N06237  1k TC=0,0
C_C1         N05580 N06237  1n  TC=0,0
V_V4         N06212 0 1m
**** RESUMING "double-ended test1.cir" ****
.END
WARNING(ORPSIM-15246): Library index file tsmc018r.ind does not have the correct format
INFO(ORPSIM-15422): Making new index file tsmc018r.ind for library file tsmc018r.lib.
*       SF_3VNA : Slow NMOS for 3.3V native NMOS                             *
*       FS_3VNA : Fast NMOS for 3.3V native NMOS                             *
* 2)HDIF depends on your layout poly spacer to contact center distance.      *
*   The value listed here is TSMC minimum-rule value. You can change it      *
*   according to your layout.                                                *
*                1.8V NORMAL DEVICES LIB                      *
***************** CORNER_LIB OF TYPICAL MODEL ***************
.LIB TT
ERROR(ORPSIM-15116): Unable to find library file TT.
Index has 0 entries from 1 file(s).
ERROR(ORPSIM-15107): Unable to make index for library file D:\fangzhen\tsmc\tsmc018r.lib.
发表于 2024-12-18 14:54:43 | 显示全部楼层
仿真文件里没选tt这个corner的model
GMT+8, 2025-10-6 09:34 , Processed in 0.012893 second(s), 4 queries , Gzip On, Redis On.
