查看: 1847|回复: 7
Help vMnager 24.09 - Failed Acquiring Required License
发表于 2024-12-11 18:04:54 | 显示全部楼层 |阅读模式
When I start VMANAGER 24.09-s001, I get the problem "license call failed". Can someone please help me?
ERROR: Server not started:
Failed Acquiring Required License - The server capabilities exceeds the licenses available - Failed to acquire bundle PROJECT_SERVER features sequence is: [VMG100-[vmanager_project:24.0], VMG200-[vmanager_integration:24.0]], last message was Failed to check-out VMG200- [vmanager_integration:24.0] with counter 1, message is :Error List Returned (-513,7006) ; Internal Flexlm Error (-506,1022) ; Internal Flexlm Error (-506,1022) ; Internal Flexlm Error (-506,1022)
Stopping server
Stopping Server.....ERROR
[OK]
$ vmanager -version
Cadence Verisium Manager: 24.09-s001: (c) Copyright 1995-2024 Cadence Design Systems Inc build:2024-10-01 13:14:06
$ uname -a
Linux dt25-linux 3.10.0- 1160.62.1.el7.x86_64 #1 SMP Tue Apr 5 16:57:59 UTC 2022 x86_64 x86_64 x86_64 GNU/Linux
vManager installation file: https://mega.nz/file/sgZiGTAZ#5I ... M9249IL-NE4luxYcUFY
发表于 2024-12-11 19:28:22 | 显示全部楼层
Follow below link, you may find an answer. B.T.W, could you share installation files?
https://bbs.eetop.cn/thread-948219-1-4.html
发表于 2024-12-12 03:53:27 | 显示全部楼层
楼上说得对,vmanager采用java,也是有check license的,所以需要patch。
发表于 2024-12-12 05:30:28 | 显示全部楼层
thanks
 楼主| 发表于 2024-12-12 09:03:11 | 显示全部楼层
https://bbs.ee ...
It's same problem, but I cannot find LmApi-xxx.jar or framwework-licsrv-***.jar in version 24.09
 楼主| 发表于 2024-12-12 09:57:05 | 显示全部楼层
I added installation file in this post
发表于 2024-12-12 18:11:06 | 显示全部楼层
use follwing bash command to find the target file, do backup first then replace java file downloaded from the page mentioned before and have a try.
find <vmanager-path> -name LmApi-*
 楼主| 发表于 2024-12-12 19:34:39 | 显示全部楼层
sinva 发表于 2024-12-12 18:11
use follwing bash command to find the target file, do backup first then replace java file download ...
I tried it, but LmApi-* did not exist
GMT+8, 2025-12-28 23:21 , Processed in 0.023386 second(s), 4 queries , Gzip On, Redis On.
