查看: 1384|回复: 4
[资料] 新手安装 Syn's fusion_com 说明
发表于 2024-11-26 17:07:58 | 显示全部楼层 |阅读模式
我在安装“Fusion Compiler”软件时也遇到了困难,花了 5 天时间才能够无错误地使用它。我从中下载安装文件的来源没有提供完整的说明。安装完成后,我已经编译了文件,安装引导文件是我根据自己的经验编写的,因此还有很多东西没有优化,希望您理解。以下是您可以参考的文档
我尝试成功运行了 Fusion 21,我还没有尝试过版本 24
以下文件包括 SCL v24.06 和 PUBKEY 1.6 文件,以及 README 文件
由于某种原因,Fusion_com 21 和 24 我尚未能够共享文件
PS: Chinese is not my first language so i may have made a lot of mistake, pls forgive me
ENG
I also had difficulties installing the "Fusion Compiler" software, and it took me 5 days to be able to use it without errors. The source from which I downloaded the installation file did not provide full instructions. After the installation is completed, I have compiled the file, and the installation boot file was written by me based on my own experience, so there are still many things that have not been optimized, I hope you understand. Here are the documents you can refer to
I've tried successfully running the Fusion compiler 21.  24 I haven't tried it yet
The following files include the SCL v24.06 and PUBKEY 1.6 files, as well as the README file
Fusion_com 21 and 24 for some reason I haven't been able to share files yet
pubkey1.6.zip
5.53 MB, 下载次数: 86 , 下载积分: 资产 -3 信元, 下载支出 3 信元
pubkey
instruct.zip
65.86 KB, 下载次数: 52 , 下载积分: 资产 -2 信元, 下载支出 2 信元
readme
 楼主| 发表于 2024-11-26 17:17:33 | 显示全部楼层
发表于 2024-11-26 20:57:58 | 显示全部楼层
can share fusion_com 24?
发表于 2025-1-11 18:38:42 | 显示全部楼层
非常感谢您的
pubkey1.6.zip
发表于 2025-8-22 19:35:59 | 显示全部楼层
感谢分享
GMT+8, 2025-10-4 11:32 , Processed in 0.091039 second(s), 4 queries , Gzip On, Redis On.
