查看: 1391|回复: 0
Verdi undefined module :VCS+Verdi仿真Xilinx IP ,Verdi波形中找不到Xilinx IP
发表于 2024-11-19 18:50:31 | 显示全部楼层 |阅读模式
按照网上的步骤编译VCS仿真库,没有报错。compile、elaborate、sim都没有error和warning.但是用Verdi打开设计时Xilinx的 IP 都是 undefined mudule.谁知道这个怎么解决吗?
报错截图
Makefile 内容
  1. f_v  = ./Temp/filelist_v.f
  2. f_sv = ./Temp/filelist_sv.f
  3. verdi_dir = /usr/Synopsys/verdi/R-2020.12-SP1/share/PLI/VCS/linux64
  4. glbl_home = /usr/Xilinx/Vivado2022.1/Vivado/2022.1/data/verilog/src
  5. SIM_PATH =$(shell pwd)
  6. SRC_PATH =$(SIM_PATH)/Source
  7. macro_sim =$(SIM_PATH)/Macro
  8. Bench_Home =$(SIM_PATH)/Testbench
  9. Bench_File =$(notdir $(wildcard $(Bench_Home)/*.v $(Bench_Home)/*.sv))
  10. Bench_Name =$(basename $(Bench_File))
  11. all: clean filelist compile elaborate simulate verdi
  12. compile:
  13.         vlogan \
  14.         -full64 \
  15.         -work Xilinx_Lib \
  16.         $(SIM_PATH)/Temp/glbl.v \
  17.         -f $(f_sv) \
  18.         -f $(f_v) \
  19.         +v2k \
  20.         -override_timescale=1ps/1ps \
  21.         +warn=all \
  22.         +incdir+$(macro_sim) \
  23.         -l $(SIM_PATH)/Temp/VCS/Compile.log \
  24.         -sverilog \
  25.         +define+SIMULATION_EN
  26.
  27. elaborate:
  28.         vcs \
  29.         -full64 \
  30.         -Mdir=$(SIM_PATH)/Temp/VCS/work \
  31.         -sverilog \
  32.         -override_timescale=1ps/1ps \
  33.         -lca \
  34.         +lint=TFIPC-L \
  35.         +lint=PCWM \
  36.         -debug_acc+all \
  37.         -P $(verdi_dir)/novas.tab $(verdi_dir)/pli.a \
  38.         -cm line+cond+fsm+tgl+branch \
  39.         -cm_dir $(SIM_PATH)/Temp/VCS/ \
  40.         -cm_log Coverage.log \
  41.         -l $(SIM_PATH)/Temp/VCS/Elaborate.log \
  42.         Xilinx_Lib.glbl        \
  43.         Xilinx_Lib.$(Bench_Name) \
  44.         -o $(SIM_PATH)/Temp/VCS/simv
  45. simulate:
  46.         $(SIM_PATH)/Temp/VCS/simv -l $(SIM_PATH)/Temp/VCS/Simulate.log +notimingcheck +nospecify -k $(SIM_PATH)/Temp/VCS/ucli.key
  47. verdi:
  48.         verdi -sv -f $(f_sv) -f $(f_v) -top $(Bench_Name) -ssf $(SIM_PATH)/WaveFile/*.fsdb
  49. clean:
  50.         @rm -rf csrc DVEfiles simv simv.daidir ucli.key VCS* AN.DB 64 verdiLog
  51.         @rm -rf novas.*
  52.         @rm -rf *.log *.vpd *.ddc *.svf *.SDF *Synth *Netlist* work vsim* transcript
  53.         @rm -rf ./Temp
  54.         @mkdir ./Temp
  55.         @mkdir ./Temp/VCS
  56.         @mkdir ./Temp/VCS/work
  57. filelist:
  58.         @cp $(glbl_home)/glbl.v        $(SIM_PATH)/Temp
  59.         [url=home.php?mod=space&uid=205858]@find[/url] $(SRC_PATH) -path "$(SRC_PATH)/Ipcore" -prune -o -type f -name "*.v" >Temp/filelist_v.f
  60.         [url=home.php?mod=space&uid=205858]@find[/url] $(SIM_PATH)/Macro/ -name "*.h" >Temp/filelist_h.f
  61.         @find $(SIM_PATH)/Testbench/ -name "*.v" >>Temp/filelist_v.f
  62.         @find $(SIM_PATH)/Ipcore/ -name "*netlist.v" >>Temp/filelist_v.f
  63.         @find $(SIM_PATH)/Model/ -name "*.v" >>Temp/filelist_v.f
  64.
  65.         @find $(SRC_PATH) -path "$(SRC_PATH)/Ipcore" -prune -o -type f -name "*.sv" >Temp/filelist_sv.f
  66.         @find $(SIM_PATH)/Testbench/ -name "*.sv" >>Temp/filelist_sv.f
  67.         @find $(SIM_PATH)/Ipcore/ -name "*netlist.sv" >>Temp/filelist_sv.f
  68.         @find $(SIM_PATH)/Model/ -name "*.sv" >>Temp/filelist_sv.f
  69.
  70. help:
  71.         [url=home.php?mod=space&uid=17569]@echo[/url] "******Welcome******"
  72.         @echo "   COMMAND LIST: "
  73.         @echo "1--- make clean "
  74.         @echo "2--- make filelist "
  75.         @echo "3--- make compile "
  76.         @echo "4--- make elaborate "
  77.         @echo "5--- make simulate "
  78.         @echo "6--- make verdi "
  79.         @echo "7--- one-click simulation, please use the command --- make all"
    复制代码
synopsys_sim.setup
  1. Xilinx_Lib : ./Temp/VCS/work
  2. OTHERS=/usr/Xilinx/VivadoLib/synopsys_sim.setup
    复制代码
GMT+8, 2025-12-13 17:27 , Processed in 0.012540 second(s), 5 queries , Gzip On, Redis On.
