楼主: TerraWilly
[Linux] $ynop$y$ VCS urg crash patch file (Will Update)
发表于 2025-5-27 16:05:11 | 显示全部楼层
是否支持2024以及以后的版本?
发表于 2025-6-3 14:52:38 | 显示全部楼层
感谢大佬分享~
发表于 2025-6-4 11:48:05 | 显示全部楼层
感谢分享
发表于 2025-6-6 17:25:30 | 显示全部楼层
exceptional thanks for the sharing. you are the great
发表于 2025-6-10 21:08:29 | 显示全部楼层
THANKS
发表于 2025-6-13 16:52:00 | 显示全部楼层
请问是替换这个文件即可吗?照着路径来?V-2023.12-SP2\linux64\lib
发表于 2025-6-27 11:12:42 | 显示全部楼层
感谢Terra! 使用补丁之后,Verdi可以查看覆盖率报告了,但合并覆盖率的时候还是报Segment Fault.
可否帮忙看一看~多谢大佬
表1.附件
附件描述附件
VCS 原始文件 libucapi-VCS-2023.12-SP1.Orig.7z (10.08 MB , 下载次数: 5 )
Verdi 原始文件 libucapi-Verdi-2023.12-SP1.Orig.7z (10.08 MB , 下载次数: 4 )
完整崩溃日志 crash.txt (29.63 KB , 下载次数: 6 )
表2.使用的补丁
补丁版本
vcs-2023.12-SP1-libucapi.Patched.zip2023.12-SP1
verdi-23.12-SP1_libucapi.Patched.zip2023.12-SP1
以下是崩溃日志的摘要:
Warning-[UCAPI-LIDW] Loading Incompatible Database
  The VDB directory 'TestNum16.vdb' was produced with version
  'V-2023.12-SP1' but you are using UCAPI version 'V-2023.12'.  Since version
  checking is being suppressed UCAPI will attempt to load the VDB anyway, but
  it may not be able to apply the data correctly.
Error-[URG-LTFF] Load test failed
  A fatal error occurred while loading the test 'TestNum16/test', and
  URG has to exit.
  The test directory may have been corrupted. Please try regenerating it. If
  the problem still persists, please contact vcs_support@synopsys.com for
  information.
An unexpected termination has occurred in /opt/Synopsys/vcs/versions/2023.12-SP1/linux64/bin/urg1 due to a signal: Segmentation fault
Hostname verify01.server.com
During the reading of coverage data file TestNum16.vdb/snps/coverage/db/shape/line.verilog.shape.xml, 8611
During reading coverage database
Command line: /opt/Synopsys/vcs/versions/2023.12-SP1/linux64/bin/urg1 -f Temporary_URG_scripts_610673_verify01.server.com_Fri_Jun_27_10:14:48_2025/dirs -full64 -noreport -nohistory -dbname Temporary_URG_db_610673_verify01.server.com_Fri_Jun_27_10:14:48_2025/tempdb_final_results/test -tests Temporary_URG_scripts_610673_verify01.server.com_Fri_Jun_27_10:14:48_2025/final_results.lst +urg+lic+wait
发表于 2025-7-3 17:24:15 | 显示全部楼层
楼主可以分享一下是如何制作替代文件的么?具体需要修改原文件哪里?
发表于 2025-7-3 19:23:24 | 显示全部楼层
感谢分享
发表于 2025-7-7 09:52:17 | 显示全部楼层
谢谢大佬分享
GMT+8, 2025-9-21 15:49 , Processed in 0.019380 second(s), 5 queries , Gzip On, Redis On.
